    Need help
    9 Posts 4 Posters 56 Views 4 Watching
    • W Offline
      windwhite
      Hello
      I am blocked with my code, I cannot connect to my LoRA [main.py
        robert-hh @windwhite
        @windwhite You can try a safe boot by either:
        • push Ctrl-F in the REPL by USB or Telnet
        • Connect P12 to 3.3V and push reset
        Safe boot will start the board without running boot.py or main.py. Then you can rename main.py. If you have a WiFi connection established, you can also connect with ftp and rename main.py.
        • W Offline
          windwhite
          my problem is establishing the connection on my LoRa network, currently my project works locally, I want to send the data in lora,
          but also reduce electricity consumption
            When using LoRa (Im guessing you mean LoRaWAN, but not sure), make sure the keys are correct (dev_eui, app_eui etc.). Next, make sure there is active coverage in your area by either your own LoRaWAN gateway or a gateway provided in the area by someone else.
            With the limited information you provide its hard to help you. I would also suggest to use a more informational topic title about the actual issue you're experiencing. In your attached code I could not find any reference to the LoRa module. Perhaps have a look at the documentation here: https://docs.pycom.io/tutorials/networks/lora/ on how to set up a lora connection.
            W 1 Reply Last reply Reply Quote 0
            • W Offline
              windwhite @Gijs
              @Gijs loraconnection.py
              I have a private Lorawan network
              here is a link to my entire project
              https://we.tl/t-FqEJtcIQZL
                livius @windwhite
                @windwhite
                probably noone will follow links on any forum ;-)
                pls describe your problem with details here.
                • W Offline
                  windwhite @livius
                  @livius I had some help for the start of my code, but in the main file I am missing the information on the connection on my private network, I am also trying to reduce the electricity consumption of my project
                    livius @windwhite
                    @windwhite
                    Sorry but you still do not provide any details.
                    Please put you code or part of code, tell with which part do you have any problems.
                    Without this you do not help us to help you, we even do not know what problem do you have, we can only guess as above @robert-hh
                    W 1 Reply Last reply Reply Quote 1
                    • W Offline
                      windwhite @livius
                      try:
                          if(message_info > 0):
                              # CONNEXION LORA ICI
                              # message_info = 0
                              # Date = str(utime.mktime(utime.localtime()))
                              # global_message[Date] = current_message
                              # print("Current : " + str(global_message))
                      except Exception as e:
                          print("Update current message exception : " + str(e))
                      I can't complete this part
