    Pybytes with intermittent connectivity
    2 Posts 2 Posters 19 Views 2 Watching
      sjj698
      Can someone please point me in the right direction to get my workflow correct.....
      I collect data, buffer it on the device and want to send IF there is connectivity. I am using the latest pybytes firmware.
      If there is connectivity all works, but if not then the device just its waiting to connect for ages.
      Can I get the device to boot, start logging and then somehow have a 'thread' that attempts to connect and transmit if successful.
      Having pybytes hang on boot is an issue.....
        You can look at this page: https://docs.pycom.io/pybytes/api/ to start pybytes manually. Set pycom.pybytes_on_boot(False). You can first setup the connection and for example check different SSID's, and when connected, call the code in the top codeblock to actually start Pybytes
