    Can't connect lopy4 using connect Device in atom with Mac
    3 Posts 2 Posters 47 Views 2 Watching
    • Y Offline
      yacine ihadadene
      I'am new to Lopy. After updating the wifi settings I want to connect again the lopy4 via USB again in order to update the firmware because I was not able to get Sigfox ID and PAC...
      The device is not visible via USB ... I tried with a windows but still facing the same issue. ( No devices detected on usb)
      Is there a way to correct this ?
      Thank you in advance.
      Regards,
      Yacine
        Please check the USB cable. There are many charging-only USB cables out there that do not support communication.
        • Y Offline
          yacine ihadadene
          Working correctly with a new usb cable.
          Thank you
          regards
