    usocket vs socket
    2 Posts 2 Posters 195 Views 2 Watching
    • H Offline
      Hamed Talebi
      Hi all,
      I am quite new to PyCom and MicroPython. I found in the documentation examples that usocket and socket used interchangeably and it seems they both are the same. The only difference is "import socket" and "import usocket". I don't know if it is correct or I mix things up?
        Both are eventually the same thing :) Because of compatibility with Python, you can call import socket, which will import the usocket library. This is explained here: https://docs.pycom.io/firmwareapi/micropython/ :)
