    Gpy with PyTrack can't get gps working
    2 Posts 1 Posters 21 Views 1 Watching
      Patrick Joy
      Hi all,
      I got a GPy + pytack this week and I'm having trouble getting the GPS library in the example zip to return coordinates. It always returns (none. none). I have read through the other topics on the forum but they mostly seem to be related to signal strength issues.
      The strange part is that when I do a location update in pybytes it works and shows my location correctly although maybe this is not using the GPS module?
      So things I have tried:
      • Updated gpy and pytrack firmware
      • Left unit outside in clear view of the sky for 12 hours
      • Tested with and without external antenna
      • Check the dump_nema method and messages are being displayed/processed
      • Tested some other versions of the gps library that have been forked/modified on github
      Any tips would be appreciated as I'm stumped!
        Patrick Joy
        Some further info on this.
        I have dumped the NMEA messages from the GPS to a file and I can see that the pytrack isn't picking up any satellites.
        I have tried with antenna jumper on/off, external and internal antenna, same result.
        Could the shield be defective?
        $GPVTG,0.00,T,,M,0.00,N,0.00,K,N*32
        $GPGGA,004345.864,,,,,0,0,,,M,,M,,*44
        $GPGSA,A,1,,,,,,,,,,,,,,,,1*03
        $GPGSA,A,1,,,,,,,,,,,,,,,,2*00
        $GPGSV,1,1,00,0*65
        $GLGSV,1,1,00,1*78
        $GPGLL,,,,,004345.864,V,N*76$GPRMC,004346.864,V,,,,,0.00,0.00,060180,,,N,V*37
        $GPGSA,A,1,,,,,,,,,,,,,,,,1*03,M,,*47
        $GPGSV,1,1,00,0*65,,,,,,,,2*00
        $GLGSV,1,1,00,1*78
        $GPGLL,,,,,004346.864,V,N*75
