How to use UART?
How can I connect an external device (GPS receiver) to LoPy and setup, configure and read in program?
Hi
did someone managed to make it work with an external GPS module
I have the data coming in but when i tried to use the lib micrpyGPS it failed since it wasn't able to allocat memory
so before starting re writing everything to convert the sentance if someone had any sketchup>>> from micropyGPS import MicropyGPS Traceback (most recent call last): File "<stdin>", line 1, in <module> MemoryError: memory allocation failed, allocating 136 bytes >>> com = UART(1,pins=("P3","P4")) >>> com.readline() b'$GPVTG,,,,,,,,,N*30\r\n' >>> com.readline() b'$GPG$GPRMC,12$GPVTG,,,,,,,,,N*30\r\n' >>> com.readline() b'$GPGGA,123243.00,,,,,0,0$GPRMC,123244.00,V,,,,,,,210217,,,N*78\r\n'
@LoneTech Ok thanks
Tip: for code formatting, use four spaces indentation. The REPL prompt
>>>will otherwise make a nested folding quote block.import os os.uname() (sysname='LoPy', nodename='LoPy', release='0.9.1.b1', version='a78d0fa on 2016-10-21', machine='LoPy with ESP32') from machine import UART com = UART(1,pins=("G23","G24")) #USE P2 P3 , keep UART 0 for usb connection com.readline() b'$GPVTG,318.32,T,,M,0.03,N,0.06,K,N*3C\r\n'
You need last firmware
import os os.uname() (sysname='LoPy', nodename='LoPy', release='0.9.1.b1', version='a78d0fa on 2016-10-21', machine='LoPy with ESP32') from machine import UART com = UART(1,pins=("G23","G24")) #USE P2 P3 , keep UART 0 for usb connection com.readline() b'$GPVTG,318.32,T,,M,0.03,N,0.06,K,N*3C\r\n' ```
