    Uploading pycom/ulab firmware build thru Pycom Firmware updater gets stuck reading file
    3 Posts 3 Posters 29 Views 3 Watching
      Daniel Near
      Re: Pycom firmwares with single/double precision and ulab module
      I was attempting to flash this using the latest Pycom Firmware Updater, and downloaded the appropriate files from GitLab. When I feed the appropriate tar.gz file to the firmware updater, i get stuck at "reading Local File", "Please wait while preparing file".. It sits there for over 2 hours. I assume this is abnormal considering the file is only a few megs and I'm on a pretty snappy workstation laptop. Intel i9 and plenty of RAM. Running Windows 10 20H2 19042.1052. Not seeing much details on troubleshooting this? I've tried a few different file versions with the same results.
        livius @Daniel Near
        @Daniel-Near said in Uploading pycom/ulab firmware build thru Pycom Firmware updater gets stuck reading file:
        You do not need firmware updater only run command something like
        make flash
          storm 1050
