TypeError: object with buffer protocol required Lora and I2C
I am receiving some data via from STM32 on my poly4 and its fine. But when i send that data via lora a get folloeng error "TypeError: object with buffer protocol required" for the line s.send(data)
Below is my code
data = '' data = uartpic.uart.read() while True: s.setblocking(True) s.send(data) utime.sleep_ms(500)For lora (https://docs.pycom.io/tutorials/networks/lora/lorawan-otaa). if i send some other data via lora(e.g. data = "Hello" s.send(data) ), it is working for me but not for data = uartpic.uart.read()
@Asim-Khan uart.read() is non-blocking. If there is no data available, it returns
None. AndNoneist not an object with a buffer protocol. Thus the error message. You have to test before sending, if you have read something from the UART.
You might have to use
struct.pack()(for multiple data pieces) orbytes(data)to transform the data object to the correct type.
