/lib/ folder in /frozen/base
  • Hi!
    We're working on getting SecureBoot and Encryption working and we have come quite long so far - everything compiles nicely except one core part of our code - the libraries. The internal libraries we have are put in a directory relative to flash, /flash/lib. They are included in the build under ...esp32/frozen/Base. I'm wondering if this is the right way to put it though, as it doesn't seem to work. Running the compiled code on the device, we get "Module not found" errors.
    See the REPL output when connected to an encrypted device:
    >>> os.listdir("/flash/lib/")
    This makes me think that there could be some kind of conflict. The building of the firmware indicates that the lib/ folder at least is being built:
    MPY frozen/base/lib/filename1.py
    MPY frozen/base/lib/dirname1/filename2.py
    I see there are multiple folders where you can put things, but they are not documented more thoroughly. For example, the Custom/ directory's README talks about "custom user scripts", but what does "custom user scripts" even mean? Therefore, I can't determine where I should put the lib/ folder or what I'm doing wrong.
    Any ideas?
  • @robert-hh Okay! Thanks a lot for that clarification and a fast answer.
  • @techykermit Actually there is no fix for that. The set of frozen files is not contained in a file-system-like structure. So you have to name the lib files in a appropriate manner.
  • @robert-hh Hi, sorry for a little late response. I had to get hold of the test unit :)
    Thanks for the command suggestion! Running it, I see that my libraries all show up, but they do show up in the list with lib/ in front of their import name. See below, where lib1, lib2 and lib3 are the internal libraries that have been frozen:
    lib/lib1 select            uqueue
    hashlib           lib/lib2 socket            ure
    json              lib/lib3
    All our previous code relies on not using lib in front of the library when importing it (for example, lib2 is imported with the line import lib2 instead of import lib.lib2 or from lib import lib2 in our source code. While the line import lib.lib2 works (so thanks a lot for pointing me to this function and figuring out that the libraries are there!), is there anything we can do to not have to change all our import statements to import from lib/ (is there anything to do so we can import the libraries from lib/ using a prefix like import lib2)?
  • @techykermit You can check with help("modules"), whether and under which name the frozen modules were included.
  • @jcaron I try to load them as you can do "normally" (when not building your custom firmware):
    for example we do:
    import log
    when we want to import the log module that is under lib.
    This gives a ModuleNotFound error:
      File "main.py", line 1, in <module>
    ModuleNotFoundError: No module named 'log'
  • @techykermit frozen files are not present as actual files in the filesystem, so it’s normal you can’t list them. They should be available for import directly.
    How do you import them and what error do you get?
  • Hi @techykermit this seems to be something that hopefully @kjm @robert-hh @jcaron @Gijs knows more about, let´s hope they can assist.
