    Error when send data on LORA ?
    2 Posts 2 Posters 32 Views 2 Watching
    • H Offline
      Haruko viet nam
      Im trying to learn how this works.... I dont get it still...
      It wont work, I was thinking it has to do with the recv part,
      maybe it has not the time to handle the bytes that are sent to the lopy.
      from network import LoRa
      import os
      import gc
      #os.uname()
      #os.getcwd() # Check where in the filesystem you are
      for cycles in range(1): # stop after 1 cycles
      lora = LoRa(mode=LoRa.LORA,tx_power = 14, sf = 7, frequency=863000000)
      s.setblocking(False)
      gc.enable()
      i = 0
      failed = 0
      counter_sent = 0
      counter_received = 0
        jcaron @Haruko viet nam
        @Haruko-viet-nam What do you expect this do do? You probably didn't copy the full code, this code doesn't do anything at all.
        Note that to quote code you should use backticks rather than quotes
        ``` not '''
        Or click on one of the </> buttons in the toolbar.
