    main.py never start
    2 Posts 2 Posters 16 Views 2 Watching
    • M Offline
      Mateusz F
      I'm newbie with lopy and pymakr
      According to this tutorial https://pycom.github.io/pydocs/gettingstarted/programming/first-project.html I create main.py file, copy-past sample code, press "Run selected file" and everything works fine - RGB LED start blinking
      Next I try to upload project to module, for the program to start automatically after connecting the power. So, I press 'upload project to device', then terminal shows information that upload finished successfully. If I press 'download from device' I can get this files, but LED not blinking. Pressing reset, disconnecting and connecting the cable, plug to another USB port - does not change anything, the program does not start automatically
      What am i doing wrong? Please help
      • E Offline
        ElectricJoe @Mateusz F
        @Mateusz-F I'm using Atom and Pymakr and usually it tells you in the REPL console if there's anything wrong with your code. Is that not the case for you?
