    Possibility to define value on JSON not been converted to string?
    1 Posts 1 Posters 26 Views 1 Watching
      Louis CONVERT
      I would like to pass data from my FiPy module to Firebase via Pybytes, using Webhooks. In that case, I'm defining a Webhook with parameters and values coming from the module. But I would like to put timestamps in the data, Firebase allows to put automatically timestamp when using the placeholder
      firebase.database.ServerValue.TIMESTAMP
      The problem is that in Pybytes, when I put the placeholder as value, it is automatically converted on the JSON as a string with double quotes ("), but then it is not interpreted by Firebase as a placeholder, and stored as string value.
      Is there any possibility to define that a value is not a string ?
      Or maybe there is a possibility on to define a CUSTOM body with the possibility to add also content type to define that it is JSON ?
      Thanks for your help !
