    PySense 2 Accelerometer sampling rate
    1 Posts 1 Posters 45 Views 1 Watching
      Amaury Basth
      Recently purchased a Lopy4 with a Pysense 2 to try to make measurements at 100Hz from the accelerometer included in the Pysense 2.
      After several attempts I am stuck at about 26Hz. :(
      The Lopy4 is up to date with the latest firmware and I am using the latest version of LIS2HH12.py with "ODR_100_HZ" ON.
      On the other hand I can't update the Pysense 2 maybe it comes from there?
      Despite the many posts in the forum on the subject I can't find an "clear" answer to this question.
      Below is the draft code I use (largely inspired by another post):
      from pycoproc_1 import Pycoproc
      import utime
      from machine import RTC
      from LIS2HH12 import LIS2HH12
      py = Pycoproc(Pycoproc.PYSENSE)
      li = LIS2HH12(py)
      # RTC sync
      rtc = RTC()
      rtc.init((2021, 7, 23, 16, 10, 0, 0, 0))
      utime.sleep_ms(250)
      print(rtc.now())
      ftime = rtc.now()
      datee = str(ftime[2]) + "/" + str(ftime[1]) + "/" + str(ftime[0])
      print("Start of recording")
      t_end = time.time() + 1
      TotalData=[]
      while time.time() < t_end:
          dataString = li.acceleration()
          ttime = rtc.now()
          timee = str(ttime[3]) + ":" + str(ttime[4]) + ":" + str(ttime[5])
          fullData2 = datee + "," + timee + "," + str(dataString)
          TotalData.append(fullData2)
          print(fullData2)
      print("Length of Total Data is : ")
      print(len(TotalData))
      pycom.rgbled(False)
      print("Record is over")```
      code_text
      Thanks for your help.
