    How to use AES CTR mode decrypt msg
    3 Posts 3 Posters 61 Views 5 Watching
    • Y Offline
      Yuzhe pei
      Hi to everyone.
      I try to create a program using AES in CTR mode.
      from crypto import AES
      import crypto
      key = b'notsuchsecretkey' # 128 bit (16 bytes) key
      counter = crypto.getrandbits(128) # hardware generated random IV (never reuse it)
      cipher = AES(key, AES.MODE_CTR, counter=counter)
      msg = cipher.encrypt(b'Attack at dawn')
      print(msg)
      # ... after properly sent the encrypted message somewhere ...
      cipher = AES(key, AES.MODE_CTR, msg[:16]) # on the decryption side
      original = cipher.decrypt(msg[16:])
      print(original)
      Output
      b'\xdb\x16\xa43\x0bfZb\x89\xae\xec\xdf\xf1\xfd'
        File "<stdin>", line 12, in <module>
      TypeError: object with buffer protocol required
      As you can see, I can encrypt msg. But when I decrypt msg, I will receive the following Error.
        g0hww
        I am using some old stable code with older firmware, and this is not using CTR mode, but CFB. I use an encrypt then MAC approach, with the IV sent between the MAC digest and the cipher text. I'm not sure how different this is to CTR mode or more recent pycom code, but hope it might help.
        cipher = AES(config.aes_key, AES.MODE_CFB,lora_in[hmac_len:hmac_len+iv_len])
        original = cipher.decrypt(lora_in[hmac_len+iv_len:])
          jcaron @Yuzhe pei
          @Yuzhe-pei where do you get msg from? My guess is that it isn’t a byte array.
