    HX711 Power Down with Lopy 4 doesn't work
    1 Posts 1 Posters 29 Views 1 Watching
      Simon RAPP
      I have a problem with a Pycom Lopy4 and an HX711. I want to put the HX711 in Power Down mode, before the Lopy4 deepsleep.
      I tried with a lot of HX711 librairies, but the function "pouwer_down" never works. I measure always 6,44mA while the current will must be around 20uA.
      This is the latest library with I tried :
      from utime import sleep_us, time
      from machine import Pin
      from micropython import const
      class HX711Exception(Exception):
          pass
      class InvalidMode(HX711Exception):
          pass
      class DeviceIsNotReady(HX711Exception):
          pass
      class HX711(object):
          Micropython driver for Avia Semiconductor's HX711
          24-Bit Analog-to-Digital Converter
          CHANNEL_A_128 = const(1)
          CHANNEL_A_64 = const(3)
          CHANNEL_B_32 = const(2)
          DATA_BITS = const(24)
          MAX_VALUE = const(0x7fffff)
          MIN_VALUE = const(0x800000)
          READY_TIMEOUT_SEC = const(5)
          SLEEP_DELAY_USEC = const(80)
          def __init__(self, d_out: int, pd_sck: int, channel: int = CHANNEL_A_128):
              self.d_out_pin = Pin(d_out, Pin.IN)
              self.pd_sck_pin = Pin(pd_sck, Pin.OUT, value=0)
              self.channel = channel
          def __repr__(self):
              return "HX711 on channel %s, gain=%s" % self.channel
          def _convert_from_twos_complement(self, value: int) -> int:
              Converts a given integer from the two's complement format.
              if value & (1 << (self.DATA_BITS - 1)):
                  value -= 1 << self.DATA_BITS
              return value
          def _set_channel(self):
              Input and gain selection is controlled by the
              number of the input PD_SCK pulses
              3 pulses for Channel A with gain 64
              2 pulses for Channel B with gain 32
              1 pulse for Channel A with gain 128
              for i in range(self._channel):
                  self.pd_sck_pin.value(1)
                  self.pd_sck_pin.value(0)
          def _wait(self):
              If the HX711 is not ready within READY_TIMEOUT_SEC
              the DeviceIsNotReady exception will be thrown.
              t0 = time()
              while not self.is_ready():
                  if time() - t0 > self.READY_TIMEOUT_SEC:
                      raise DeviceIsNotReady()
          @property
          def channel(self) -> tuple:
              Get current input channel in a form
              of a tuple (Channel, Gain)
              if self._channel == self.CHANNEL_A_128:
                  return 'A', 128
              if self._channel == self.CHANNEL_A_64:
                  return 'A', 64
              if self._channel == self.CHANNEL_B_32:
                  return 'B', 32
          @channel.setter
          def channel(self, value):
              Set input channel
              HX711.CHANNEL_A_128 - Channel A with gain 128
              HX711.CHANNEL_A_64 - Channel A with gain 64
              HX711.CHANNEL_B_32 - Channel B with gain 32
              if value not in (self.CHANNEL_A_128, self.CHANNEL_A_64, self.CHANNEL_B_32):
                  raise InvalidMode('Gain should be one of HX711.CHANNEL_A_128, HX711.CHANNEL_A_64, HX711.CHANNEL_B_32')
                  self._channel = value
              if not self.is_ready():
                  self._wait()
              for i in range(self.DATA_BITS):
              self._set_channel()
          def is_ready(self) -> bool:
              When output data is not ready for retrieval,
              digital output pin DOUT is high.
              return self.d_out_pin.value() == 0
          def power_off(self):
              When PD_SCK pin changes from low to high
              and stays at high for longer than 60 us ,
              HX711 enters power down mode.
              sleep_us(self.SLEEP_DELAY_USEC)
          def power_on(self):
              When PD_SCK returns to low, HX711 will reset
              and enter normal operation mode.
              self.channel = self._channel
          def read(self, raw=False):
              Read current value for current channel with current gain.
              if raw is True, the HX711 output will not be converted
              from two's complement format.
                  self._wait()
              raw_data = 0
                  raw_data = raw_data << 1 | self.d_out_pin.value()
              self._set_channel()
              if raw:
                  return raw_data
                  return self._convert_from_twos_complement(raw_data)
      Is someone know how to fix this problem ?
      Best regards,
      Simon
