    Problem Serial port connexion and save file voltage variable
    1 Posts 1 Posters 43 Views 1 Watching
    • H Offline
      HAMMOUTI
      from machine import ADC
      import os
      import io
      adc = ADC()
      bat_voltage = adc.channel(attn=ADC.ATTN_11DB, pin='P16')
      vbat = bat_voltage.voltage()
      with open("vbatmv.txt", "a+") as f:
       while True :
          # note that the expansionboard 3 has a voltage divider of 1M / 1M to account for
          # 1M / 1M, ratio = 1:2
          vbat = vbat*2
          time.sleep(30)
          print('battery voltage:', vbat, 'mV')
          print(vbat, file=f)
      Hi, I can you help me to solve this problem , I try to save voltage value in file with print command some time work other not , and i have problem to connect tool upycraft to my pycom board 3.1 serial port in execution of this programme .
