    Socket udp EINPROGRESS OSError
    1 Posts 1 Posters 46 Views 1 Watching
    • F Offline
      Francesco Pugliese
      Dear all,
      I am developing a fw which have to send to my pc a data. O the other side there is a server udp in my PC(a script written in Pycharm).
      Client:
      class UDP:
      def init(self):
      self.wlan = WLAN(mode=WLAN.STA)
      self.wlan.connect(ssid='AP_Progettazione', auth=(WLAN.WPA2, 'Progettazione2019'))
      while not self.wlan.isconnected():
      time.sleep(0.25)
      print("Wifi .. Connecting")
      print ("Wifi Connected")
              self.socket_list = []
      Set up the first socket in non-blocking mode
              self.s1 = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
              self.s1.setblocking(False)
              self.socket_list.append(self.s1)
              # Set up the second socket in non-blocking mode
              self.s2 = socket.socket()
              self.s2.setblocking(False)
              self.socket_list.append(self.s2)
              self.s1s = ssl.wrap_socket(self.s1)
              self.s2s= ssl.wrap_socket(self.s2)
              # Create a new poll object
              self.p = uselect.poll()
              # self.s1.settimeout(10)
              # self.s2.settimeout(10)
              # Register the sockets into the poll object, wait for all kind of events
              self.p.register(self.s1, uselect.POLLIN | uselect.POLLOUT | uselect.POLLHUP | uselect.POLLERR)
              self.p.register(self.s2, uselect.POLLIN | uselect.POLLOUT | uselect.POLLHUP | uselect.POLLERR)
              try:
                  self.s2s.connect(socket.getaddrinfo("192.168.1.31", 80)[0][-1])
                  self.s1s.connect(socket.getaddrinfo("192.168.1.31", 80)[0][-1])
                  print("SOCKET CREATE")
              except OSError as e:
                      if e.args[0] != uerrno.EINPROGRESS:
                          raise
              # Raise all other errors
      def Send_datagram(self,p):
          # Wait for any action to happen infinitely
              l = self.p.poll()
          # Start processing the actions happened
              for t in l:
              # First element of the returned tuple is the socket itself
                  sock = t[0]
                  # Second element of the returned tuple is the events happened
                  event = t[1]
              # If any error or connection drop happened close the socket
                  if(event & uselect.POLLERR or event & uselect.POLLHUP):
                      sock.close()
                      continue
              # If the socket is writable then send some data
              # The socket becomes writable if the connect() was successfull
                  if(event & uselect.POLLOUT):
                  # If any error occurs during sending here, do "nothing", poll() will return with error event, close the socket there
                      try:
                          sock.send("Data to send")
                      # We only want to send one message on this socket, in the future wait only for new incoming messages
                          self.p.modify(sock, uselect.POLLIN | uselect.POLLHUP | uselect.POLLERR)
                      except:
                          pass
              # If any new data is received then get it
                  if(event & uselect.POLLIN):
                  # If any error occurs during receiving here, do "nothing", poll() will return with error event, close the socket there
                      try:
                          r = sock.recv(1)
                      # If recv() returns with 0 the other end closed the connection
                          if len(r) == 0:
                              sock.close()
                              continue
                          # Do something with the received data...
                              print("Data received: " + str(r))
                      except:
                          pass
      def Thread(self):
          print("Questo è il thread che manda via udp")
          _thread.start_new_thread(self.Send_datagram,(self.p,))
      Server:
      localIP = "127.0.0.1"
      #localIP ="192.168.1.31"
      localPort = 80
      bufferSize = 1024
      msgFromServer = "Hello UDP Client"
      bytesToSend = str.encode(msgFromServer)
      Create a datagram socket
      UDPServerSocket = socket.socket(family=socket.AF_INET, type=socket.SOCK_DGRAM)
      Bind to address and ip
      UDPServerSocket.bind((localIP, localPort))
      print("UDP server up and listening")
      Listen for incoming datagrams
      while (True):
      bytesAddressPair = UDPServerSocket.recvfrom(bufferSize)
      message = bytesAddressPair[0]
      address = bytesAddressPair[1]
      clientMsg = "Message from Client:{}".format(message)
      clientIP = "Client IP Address:{}".format(address)
      print(clientMsg)
      print(clientIP)
      # Sending a reply to client
      UDPServerSocket.sendto(bytesToSend, address)
      How can I resolve this?
      Thanks in advance
      Let me know
      Francesco Pugliese
