Pysense Board is not connecting
Hi guys, I'm starting an IoT project and I have the following problem:
I'm using Visual Studio Code with the Pymakr extension, and when I connect my Pysense Board via USB it get stuck with the following message "Connecting to /dev/ttyACM0..." but never connects.
I've tried giving permissions with "sudo usermod -a -G dialout $USER" but nothing has changed.
I've also tried using Atom and connecting the board via screen and nothing happens either.
By the way: I'm on Linux Mint 20.1 in a Lenovo IdeaPad Gaming 3.If someone can help me I will be very grateful.
Thanks!
Same issue over here, wipy3 NOT detected via WiFi nor USB, the light is blinking blue. After OTA updating. I left from Pycom no response in all topic. No way to recovery a CORRUPTED FIRMWARE!!
@jcaron Same issue over here- Pysense with Sipy is NOT detected via WiFi nor USB- the light is blinking blue…
@Alejo-Severini-Montanari what development module do you have installed on the Pysense? It is in the right orientation? Is the LED on the module flashing blue?
