    How to change the role of a leader router in a pymesh network ?
    1 Posts 1 Posters 20 Views 1 Watching
    • R Offline
      rayan malro
      Hello everyone,
      I wonder if it is possible to manually set a specific router as a leader in a Pymesh network
      I use 3 Fipy (=routers) and here is the firmware version: Pycom MicroPython 1.20.2.rc11
      I use this repo without using pybytes: https://github.com/pycom/pycom-libraries/tree/master/pymesh/pymesh_frozen
      When the mesh network is running, a leader is defined automatically. I would like to manually change its router role to set another leader in the network.
      I tried to change the leaderweight to increase the probability of a router becoming a leader with the following command:
      pymesh.leader_priority(2)
      In addition, I tried to change the role of a router and to set the current leader as a simple router following this cli command :
      # code used to define the router as a leader
      pymesh.ot_cli('state leader')
      # code used to define the current leader as a router
      pymesh.ot_cli('state router')
      But this does not work. The leader router of the original network reverts to its role as leader.
      Thanks in advance for any answer,
      Have a great day
