    Cannot join using OTAA.
    3 Posts 2 Posters 39 Views 2 Watching
    • H Offline
      hakan kayan
      I am trying to establish a LoRa communication. I am a beginner.
      First of all, the GitHub code is different than the webpage tutorial. I am not sure which one to follow. I tried both.
      The problem was mentioned in another topic around 4 years ago. But sadly, it seems like the issue still persists.
      I have 1 LoPy and 1 LoPy4. I am using LoPy as end node, and LoPy4 as a gateway. I registered both to TTN. The gateway receives uplink messages but my device can never join.
      How can I debug this further?
        robert-hh @hakan kayan
        @hakan-kayan You could switch the devices. The Lopy works better as gateway. Since it has no SPIRAM, timing is more reliable.
        • H Offline
          hakan kayan @robert-hh
          Hi @robert-hh,
          I tried, sadly still no success. Here is what I see in my TTN gateway activity. It does not allow me to put a picture so I am adding as a code:
          Receive uplink message        JoinEUI: something       DevEUI: something        Data rate: SF7BW125
          The output of node LoPy as follows:
          Not yet joined...
          Here is my code on node:
          """ OTAA Node example compatible with the LoPy Nano Gateway """
          from network import LoRa
          import binascii
          import struct
          import config
          # initialize LoRa in LORAWAN mode.
          # Asia = LoRa.AS923
          # Australia = LoRa.AU915
          # Europe = LoRa.EU868
          # United States = LoRa.US915
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
          # create an OTA authentication params
          dev_eui = binascii.unhexlify('something')
          app_eui = binascii.unhexlify('something')
          app_key = binascii.unhexlify('something')
          # set the 3 default channels to the same frequency (must be before sending the OTAA join request)
          lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
          # join a network using OTAA
          lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=config.LORA_NODE_DR)
          # wait until the module has joined the network
          while not lora.has_joined():
              time.sleep(2.5)
              print('Not joined yet...')
          # remove all the non-default channels
          for i in range(3, 16):
              lora.remove_channel(i)
          # create a LoRa socket
          # set the LoRaWAN data rate
          s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
          s.setblocking(False)
          time.sleep(5.0)
          for i in range (200):
              pkt = b'PKT #' + bytes([i])
              print('Sending:', pkt)
              s.send(pkt)
              time.sleep(4)
              rx, port = s.recvfrom(256)
              if rx:
                  print('Received: {}, on port: {}'.format(rx, port))
              time.sleep(6)
