    CORE DUMP - MODETH Lib
    2 Posts 1 Posters 29 Views 2 Watching
      Andrea Picillo
      Hi there!
      I'm having some problems regarding some sporadic Core Dump Errors.
      Traceback log is something like that:
      Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
      Core 1 register dump:
      PC      : 0x40096ca3  PS      : 0x00060833  A0      : 0x80095afd  A1      : 0x3ffd1c00
      A2      : 0x3ffd1e68  A3      : 0x00060823  A4      : 0x3ffd1e4c  A5      : 0x00000001
      A6      : 0x000000fe  A7      : 0x3fbc2fec  A8      : 0x00000000  A9      : 0x3ffd1e68
      A10     : 0x3ffd1e68  A11     : 0x0000abab  A12     : 0x3ffd1e4c  A13     : 0x00000001
      A14     : 0x000000fe  A15     : 0x00000000  SAR     : 0x0000001e  EXCCAUSE: 0x0000001c
      EXCVADDR: 0x00000004  LBEG    : 0x400929b0  LEND    : 0x400929de  LCOUNT  : 0x00000000
      Backtrace gives to me the following result:
      uxListRemove
      /home/peter/docs/pycom-esp-idf/components/freertos/list.c:218
      xTaskRemoveFromEventList
      /home/peter/docs/pycom-esp-idf/components/freertos/tasks.c:3092
      xQueueGenericSend
      /home/peter/docs/pycom-esp-idf/components/freertos/queue.c:767
      sys_sem_signal
      /home/peter/docs/pycom-esp-idf/components/lwip/port/esp32/freertos/sys_arch.c:133
      sys_arch_unprotect
      /home/peter/docs/pycom-esp-idf/components/lwip/port/esp32/freertos/sys_arch.c:483
      do_memp_malloc_pool
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/core/memp.c:346
      memp_malloc
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/core/memp.c:398
      tcpip_inpkt
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/api/tcpip.c:207
      tcpip_input
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/api/tcpip.c:248
      ethernetif_input
      /home/peter/docs/pycom-esp-idf/components/lwip/port/esp32/netif/ethernetif.c:224
      tcpip_adapter_eth_input
      /home/peter/docs/pycom-esp-idf/components/tcpip_adapter/tcpip_adapter_lwip.c:1096
      process_rx
      /media/Project/esp32/mods/modeth.c:249
      Please could you help me in finding out some causes about that?
      I would appreciate that.
      Thank you very much.
      Greetings,
      Andrea
        Andrea Picillo
        I also noticed that somethings different happens into TCP packets:
        As you can see I received plenty good packets without any errors.
        Suddenly I start receiving some "TCP Retransmission" or "DUP ACK".
        The situation doesn't change in time when that happens. I mean that these "abnormal" packets will be received forever.
        It seems that the at final stage it brings to the stuck of the Pycom Module and the Core Dump or WDT time out.
