    IP67 Case & PySense Board
    ip67pysensecase
    2 Posts 2 Posters 974 Views 2 Watching
    • M Offline
      MaSePreetz Pybytes Beta
      Hi all,
      i am currently look at the available cases for the *Pys i have.
      I discovered that the IP67-Case is available soon, as is the PySense board.
      Some questions do arise:
      • If i use the PySense board in the IP67 case, some sensors (humidity, temperature, barometric pressure) will not work ??!!
        (Temperature might work but with significant delay?)
      • The PySense board does not support positioning (at least no sensor is mentioned, but the description says so)
      Are my assumptions right and the IP67 case does not make sense with the PySense board?
      Many thanks in advance,
      Marc
        Jordan Reyes
        Did anyone ever answer or try this? @MaSePreetz @Pycom-Pyoneers @Global-Moderators
