fipy no repl after firmware upgrade, safe boot doesn't help
I have a fipy & expansionboard v3.1.
I upgraded the firmware on the expansionboard, then tried upgrading the fipy.
The upgrade utility says the upgrade was successful:
But I cannot get the repl prompt. The heartbeat seems to be going. I've tried the safeboot button and I do get the different LED flash rates, but still no repl.
If I press the reset button while putty is attached I get this:
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2128 load:0x4009fa00,len:19760 entry 0x400a05bc ets Jun 8 2016 00:22:57Sometimes that last line doesn't show up.
Any suggestions on how to get the fipy talking again?
Regards, David.
@David-Taylor said in fipy no repl after firmware upgrade, safe boot doesn't help:
Hi David,
It's worth checking what safeboot is doing. You don't say what the LED is doing, but the documentation is here
https://docs.pycom.io/gettingstarted/programming/safebootIf that doesn't work you could erase the flash with the cli updater and reflash.
https://docs.pycom.io/advance/cli/
