Nice method to check if SD-card is removed
Hi folks,
I'm looking for a nice way to check if an SD card has been removed.
After a succesful OTA update from the SD card, I have a reason to not reboot right away, but wait until the SD card has been removed.
I understand that I could stat() a file until it is no longer valid, but that's not really a solution to me.
Maybe one of the pins has a certain behaviour when card is present / not present? -
@Steven-Boonstoppel
What device?
If you use cusom sdcard (attached by wires) then there are plenty of slots with card remove detect pin. -
@livius LoPy4 with Expansion Board v3(.1)
@Steven-Boonstoppel said in Nice method to check if SD-card is removed:
Expansion Board v3
I do not use Expansion Board so cannot help
