    Sipy going crazy over the serial port something says Core Dump
    sipy
    8 Posts 2 Posters 2.2k Views 3 Watching
    • I Offline
      iotmaker
      have any of you had this problem before?
      i did a flash clean and it is still happening... gonna try the firmware reset now
      • I Offline
        iotmaker
        i guess all pycom support or daniel is busy at the Mobile World Congress
          daniel
          Have you tried with the firmware from yesterday? What do you have as your boot.py and main.py?
            daniel
            I have tried on a clean SiPy and no crashes. It's probably related to your main/boot files. Can you share what you have in them?
            • I Offline
              iotmaker
              is still randomly happening... once i finish the code i will post it... so far the solution has been unplug the usb port and plug it again...
              if i do machine.reset()
              is when it starts to happen
              • I Offline
                iotmaker @daniel
                @daniel
                0_1488235701679_main.py
                this is the code that is crashing
                • I Offline
                  iotmaker
                  Is there a reason for this DUMPS or crashings @daniel? could you explain why they happen?
                    daniel
                    @iotmaker, I'll have to check, the reason is not obvious, I'll keep you posted.
