    Unable to satisfy from uasyncio.websocket.server import WSReader, WSWriter
    1 Posts 1 Posters 46 Views 1 Watching
      Gary Kuipers
      Problem: I have a program that uses this:
      import uasyncio
      I have tried:
      upip.install('uasyncio')
      upip.install('uasyncio.websocket')
      upip.install('uasyncio.websocket.server')
      First Steps: (Proof of virginity)
      python3 /home/gk/.local/bin/esptool.py --chip esp32 --port /dev/ttyUSB0 erase_flash
      python3 /home/gk/.local/bin/esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 460800 write_flash -z 0x1000 ../esp32-20220618-v1.19.1.bin
      Set up boot.py for network access and boothed the ESP32
      Starting from the top: upip.install('uasyncio')
      import upip
      Installing to: /lib/
      Warning: micropython.org SSL certificate is not validated
      Installing uasyncio 3.0 from https://micropython.org/pi/uasyncio/uasyncio-3.0.tar.gz
      then:
      import main
      ImportError: no module named 'uasyncio.websocket'
      Fair enough: do first steps again for a virgin board: upip.install('uasyncio.websocket')
      import upip
      Error installing 'uasyncio.websocket': Package not found, packages may be partially installed
      Here I am confused ... how can it be "partially installed" if the board was cleared and the bin re-written to it?
      OK, so: do first steps again for a virgin board: no upip install this time:
      import main
      Not sure what is going on.
      Help please!
      Thisis from: https://forum.micropython.org/viewtopic.php?f=15&t=6568
      <code>
      import uasyncio
      def echo(reader, writer):
      # Consume GET line
      yield from reader.readline()
      reader = yield from WSReader(reader, writer)
      writer = WSWriter(reader, writer)
      while 1:
          l = yield from reader.readline()
          print(l)
          if l == b"\r":
              await writer.awrite(b"\r\n")
              await writer.awrite(l)
      import logging
      logging.basicConfig(level=logging.INFO)
      logging.basicConfig(level=logging.DEBUG)
      loop = uasyncio.get_event_loop()
      loop.create_task(uasyncio.start_server(echo, "192.168.4.1", 8081))
      loop.run_forever()
      loop.close()
      </code>
