    Cannot connect BLE in LoPy
    5 Posts 2 Posters 138 Views 2 Watching
    • F Offline
      Fikret Avci
      Hi all,
      I have a LoPy device and I want to connect a device via Bluetooth. It can read the advertises, but it cannot connect the device. Is there any Bluetooth setting I need to set in LoPy device or the corresponding device, or is there any way to debug it? The adv_type I am receiving is 0. Here is the code I am trying:
      from network import Bluetooth
      bt = Bluetooth()
      bt.start_scan(-1)
          adv = bt.get_adv()
          if adv and bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'BBC micro:bit [zaput]':
              print(adv.adv_type)
              try:
                  conn = bt.connect(adv.mac)
                  print('connected')
                  services = conn.services()
                  for service in services:
                      time.sleep(0.050)
                      if type(service.uuid()) == bytes:
                          print('Reading chars from service = {}'.format(service.uuid()))
                          print('Reading chars from service = %x' % service.uuid())
                      chars = service.characteristics()
                      for char in chars:
                          if (char.properties() & Bluetooth.PROP_READ):
                              print('char {} value = {}'.format(char.uuid(), char.read()))
                  conn.disconnect()
                  break
              except:
                  print("Error while connecting or reading from the BLE device")
                  break
              time.sleep(0.050)
      Also, I am getting these lines as the output and firmware version:
      0
      Pycom MicroPython 1.20.2.r6 [v1.11-c5a0a97] on 2021-10-28; LoPy with ESP32
      Pybytes Version: 1.7.1
        jcaron @Fikret Avci
        @Fikret-Avci Are you able to connect to the device using a different device, like a smartphone with nRF Connect for instance (or one of the many other BLE scanners)?
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          Fikret Avci
          @jcaron I can connect other device with app on the smart phone. Also, I could connect LoPy when I use it as server.
          • F Offline
            Fikret Avci @jcaron
            • F Offline
              Fikret Avci
              It says OSError: connection refused after trying to connect with connect(adv.mac)
