    Pycom fipy works fine with ABP, but not with OTAA
    2 Posts 2 Posters 79 Views 2 Watching
      Dale Fletcher Banned
      I have a Things Gateway established here with a ThingsNode connecting and communicating with it without trouble using ABP.
      My poor little Pycom fipy, on the other hand, will only connect with ABP. If I try the following example using OTAA, I receive no response from the TTN gateway and the fipy merely loops printing "Not joined yet."
      Any suggestions on how I can debug and figure out what's going on?
      from network import LoRa
      import binascii
      app_eui = binascii.unhexlify('<app eui key here>')
      app_key = binascii.unhexlify('<app key here>')
      # wait until the module has joined the network
      while not lora.has_joined():
          time.sleep(2.5)
          print('Not joined yet...')
      print('Network joined!')```
        robert-hh @Dale Fletcher
        @Dale-Fletcher Which firmware version do you use?
        The time window for receiving a OTAA join confirmation is small (~10 ms after 5 or 6 seconds) and the PyCom (ESP32) device have not
        You could try to join with a lower data rate or init Lora with a higher spreading factor. That will increase the time window for receive.
        Edit: Do you see the join request in the TTN gateway console?
