    Pycom Sigfox - Weak Signal Reception
    2 Posts 2 Posters 61 Views 2 Watching
      Jaco Pretorius
      Good day
      Problem:
      According to the Sigfox coverage network on site our area has great reception. But if I use the standard 868MHz, 190mm Areal (NEW) and send Data (only 3 Bytes) every 5 minutes. I am only able to receive 2 messages in a Hour. Out Area is South Africa (RCZ1).
      My Question:
      What is the output power that the Pycom Sipy Module supply to the Antenna? and can I use a two meter antenna on the Pycom Sipy Module to boost the signal?
      Or is there some thing else that i could look at?
      Code Example:
      from network import Sigfox
      from machine import Timer
      #********************* Setup Comms *********************#
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
      s.setblocking(True)
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
      #********************* Send Bytes Interupt *********************#
      def MsgTimer_Handler(arg):
      print("Sending message")
      s.send(bytes([0x01, 0x02, 0x03]))
      #********************* Timer *********************#
      MsgTimer = Timer.Alarm(MsgTimer_Handler, 300, periodic=True)
      print("Timer Started...")
      print(str(sigfox.rssi()))
        jcaron @Jaco Pretorius
        @Jaco-Pretorius In RC1, there is a duty cycle limit at 1%, measured per hour.
        This means you can send at most 6 messages per hour (6 messages taking 6 seconds of airtime each = 36 seconds per hour = 1%, so one message every 5 minutes is not possible.
        Not sure how or why you then only get 2, but it may be related to how the duty cycle limit is implemented.
        Regarding the antenna, a larger antenna is not necessarily better, what makes a difference is antenna gain (a bit, but watch out for EIRP limits!) and line-of-sight.
        You can try to test outside, in an area with no obstacles around (buildings, trees, hills), on a high point, to see if that makes a difference.
        But change your interval first, set it to 10 minutes or more to see the result.
