    Such a newb...
    3 Posts 2 Posters 366 Views 2 Watching
    • K Offline
      Kurt switzer
      I have written some simple code to control a few stepper and DC motors. Suddenly today the proven code stopped working with the Traceback.....KeyboardInterrupt: error. This code ran this morning and won't now. I even took the PICO W off the breadboard and tried to run the day one training code.
      from machine import Pin
      from time import sleep
      myLED=Pin('LED',Pin.OUT)
          #myLED.value(0)
          #sleep(.1)
          #myLED.value(1)
          #sleep(.1)
          myLED.off()
          sleep(.019)
      I'm still getting the unidentified error, and no, I am not pressing CTRL-C.
      Any ideas on what obvious thing I'm doing wrong?
      robert-hhR 1 Reply Last reply Reply Quote -1
        robert-hh @Kurt switzer
        @Kurt-switzer Are you sure that you post in the right forum? This is the Pycom forum. If you have a Pico W, you should go to https://github.com/orgs/micropython/discussions
        Besides that, Keyboard Interrupt is caused by the PC host, sending Ctrl-C. Do you have a Modem Manager running on the PC. At Linux it is enabled by default. So you have to disable it. Other causes may be bad USB cables.
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          Kurt switzer @robert-hh
          @robert-hh maybe wrong forum. I couldn't figure out the Github system and found this forum instead. Thanks for the tip on the USB cable. Hope it's that simple. .
