    Can't seem to fint the I2C pins on the expansion board (using SiPy)
    i2csipyexpansionboard
    5 Posts 3 Posters 2.5k Views 3 Watching
      Lokefar
      The problem is more or less stated in the title. Can anyone tell my what the I2C pins are called? Preferable both on the expansion board and on the SiPy? Really wanna understand it.
        livius @Lokefar
        @Lokefar
        you can start I2C on "any" pins
        default are pins P9 (SDA) and P10 (SCL)
        you can choose different by putting it in below code instead SDA SCL text
        i2c.init(mode, *, baudrate=100000, pins=(SDA, SCL))
        more info here:
        https://docs.pycom.io/pycom_esp32/library/machine.I2C.html
        look at pinout:
        Sipy
        https://docs.pycom.io/pycom_esp32/_downloads/Sipy_v01_1_pinout_rc.pdf
        expansion
        https://docs.pycom.io/pycom_esp32/_downloads/exp_v03_pinout_v13.pdf
          Shaun
          Looks like the SDA, SCL and MOSI, MISO, CLK and RX0, TX0 and RX1, TX1 labels have all been removed in the latest drawings.
            livius @Shaun
            @Shaun
            You have right
            @Lokefar look at pinout of Lopy it should be near same
            https://docs.pycom.io/pycom_esp32/_downloads/lopy_pinout.pdf
              Lokefar
              Thanks to Livius. That worked!
