    New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!)
    firmware
    113 Posts 34 Posters 88.8k Views 32 Watching
      Colateral @robert-hh
      @robert-hh I believe I know what was happening. If you jump from Wipy default AP to the new AP (as STA_AP) having the same MAC and you try to connect Wipy to the wifi router where computer is plugged with the Lan cable... . Windows 10 is going to be confused. After I restarted windows and unplugged the cable everything is working fine.
      Z 1 Reply Last reply Reply Quote 0
        gas @gas
        @gas said:
        router.eu.thethings.network:1700
        we are talking at the TTN side right
        Description            lopyNanoGW
        Status                      not connected
        Frequency Plan      Europe868MHz
        Router      router.eu.thethings.network:1700
        J R 2 Replies Last reply Reply Quote 0
          jmarcelino @gas
          @gas
          On TTN have you registered the gateway as "gateway connector" or "packet forwarder" under Protocol?
          You have to register as "packet forwarder"
          TTN will also automatically add a 'eui-' prefix to your gateway ID if you chose the correct one.
          G 1 Reply Last reply Reply Quote 1
          • R Offline
            rskoniec @gas
            @gas Here is my TTN config:
            Gateway should be packet forwarder type.
              gas @jmarcelino
              @jmarcelino
              your right i was using the Gateway not the packet forwarder
              now it is connected cool
              but the exampe of otaa is wrong
              lora.join don't se deveui
              my node is connected over my Lopy LoRaWAN nanaGW OTAA
              github should be updated
                daniel
                @gas, yes, the example force the deveui to some value, I'll update the code on githb to clarify that. Thanks!
                  gas @daniel
                  @daniel
                  Great Job any and impressive both micropython and Pycom
                  now let me try the range with my sample code of GPS ...
                    daniel
                    @thanks! keep us posted about your results :-)
                      @robert-hh I tried Windows10 ftp in browser as ftp://micro:python@192.168.4.1
                        ThatStudentGuy
                        After upgrading to the latest firmware i'm no longer able to send using raw Lora mode. I'm running the same code as i did before the weekend and it worked then. The code is basically the LoPy to LoPy code for sending and receiving. I did the firmware update. I tried to play around with the public parameter as told earlier but with no result.
                        Anyone else experiencing the same problem?
                          Clemens @ThatStudentGuy
                          @ThatStudentGuy The public parameter is for talking from LoPy to RFMs necessary. Your problem is related to theat but not the public variable. Unfortunately there was a major change in the LoRa specification section, you have to set parameter expicitly now, see
                          https://forum.pycom.io/topic/770/lora-receiving-only-b
                          It's a bit annoying that now all defailt examples here in the forum and also on git no more working, from y perspectiv a no go and very frustrating for new users. You are tolde that you have to update your board but the "simplest code you can get" is not working, see my comments about that under:
                          https://forum.pycom.io/topic/770/lora-receiving-only-b/4
                          In case there is a need for this heavily change it must be documented on a prominent location or the next release must have a kind of change or fix. Just my 2 cents! ;-)
                            ThatStudentGuy @Clemens
                            @Clemens
                            Thanks for your answer. That was indeed the problem.
                            • M Offline
                              Movsun
                              I have successfully connect the LoPy to TTN. But when I try the ABP and OTAA code on other LoPy I don't see data in TTN device. and device status is never connect. I use "binascii.hexlify(lora.mac()).upper().decode('utf-8')" to get my device EUI to register my device in TTN. and use the key they generate to put in the example code.
                              I have already update the to device to 1.6.7.b1. What should I try to find the problem?
                                daniel
                                @Movsun if you look at the OTAA example, you'll see that we are hardcoding the DEV_EUI:
                                # join a network using OTAA
                                lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
                                Do the join like this in order to use the MAC address of the LoPy as EUI:
                                  livius @daniel
                                  @daniel
                                  It looks like STA_AP mode work ok
                                  and there is some issue with Windows10 system not Wipy itself
                                  fixed by tip from @Colateral
                                  https://forum.pycom.io/topic/679/ap-sta-mode/5
                                  And another +
                                  on 1.6.7 i do not see corruption of files compared to 1.6.3 version :)
                                  • R Offline
                                    rskoniec
                                    Sometimes I see series of W (xxxxxxxxx) wifi: post pm rx bcn failed messages on my LoRaWAN Nano Gateway:
                                    Push ack
                                    Push ack
                                    Push ack
                                    W (147750288) wifi: post pm rx bcn failed
                                    Pull ack
                                    Pull ack
                                    Pull ack
                                    and Downlink timestamp error!, t_us: xxxxxxxxxx messages:
                                    Push ack
                                    Downlink timestamp error!, t_us: 4295216794
                                    Pull rsp
                                    Push ack
                                    Downlink timestamp error!, t_us: 4295288926
                                    Pull rsp
                                    Pull ack
                                    Push ack
                                    Downlink timestamp error!, t_us: 4295280463
                                    Pull rsp
                                    Push ack
                                    Pull ack
                                    I would like to know a little bit more about these.
                                    Thank you in advance.
                                      daniel
                                      @rskoniec I'm also seeing those and I'm investigating the cause together with Espressif.
                                      • M Offline
                                        Movsun @daniel
                                        @daniel Thank you, And if I want to use 250 khz bandwidth. which code should I modify in both the gateway and node?
                                        • R Offline
                                          rskoniec @daniel
                                          @daniel said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
                                          OK, thank you @daniel I hope you'll find the cause of those.
                                            daniel @Movsun
                                            @Movsun just change the bandwidth (to make it 250 KHz) argument in the LoRa constructor for both LoPy's.
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 6
                                            • 3 / 6
