    Sipy only send first message when restart
    rcz2mexicofirst message
    12 Posts 4 Posters 3.6k Views 4 Watching
    • I Offline
      irvinvp
      Hi Pycom Community,
      I'm trying to send 1 message every 5 minutes manually with this code:
      from network import Sigfox
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ2)
      s.setblocking(True)
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
      s.send('message')
      then only repeat this:
      s.send('message')
      But only the first message is out and then not one more, until I restart again. What could be the problem?
      PD. I´m trying with RCZ2 on Mexico
      • B Offline
        bucknall
        Hi @irvinvp could you post your complete snippet with the loop for every 5 minutes?
        It may have something to do with how you are looping your code.
        Thanks!
        Alex
        Developer Evangelist - Pycom
        • I Offline
          irvinvp
          Hi @bucknall,
          For now i'm sending manually, only typing s.send('message') every time.
          Thanks,
          Irvin
          • B Offline
            bucknall @irvinvp
            @irvinvp can you show me your terminal after you send a message? It should return the number of bytes that were sent after each message
            • I Offline
              irvinvp @bucknall
              @bucknall Yes, every time returns the number of bytes, i'm try to send 12 bytes or less, with same result.
              Some times take more time the return of the number, but if i restart the sipy the first message is send every time.
              • B Offline
                bucknall
                @irvinvp If you placed your code into the main.py file then this should be normal behaviour if you restart?
                Apologies, I'm not sure that I'm following exactly what your question is!
                Thanks,
                Alex
                • I Offline
                  irvinvp @bucknall
                  @bucknall The problem is that the following messages do not arrive, for example:
                  First i type this:
                  s.setblocking(True)
                  s.send('message')
                  # This message arrive to Sigfox server
                  then i type this:
                  s.send('message') # This message not arrive to Sigfox server
                  then wait and i type this:
                  Then if i restart and repeat the process only the first message is arrived to Sigfox server!
                  • B Offline
                    bucknall @irvinvp
                    @irvinvp Ahh ok! I understand your concern! Let me give this a test and see if I can resolve your issue!
                    Thanks,
                    Alex
                    • I Offline
                      iotmaker
                      Do you wait some time between sending messages? are you on an area that is covered by Sigfox?
                      You could call the IotMx guys they manage the network. or check the sigfox api
                      Coverage API
                      Redundancy
                      Get base station redundancy for a given latitude and longitude.
                      Request
                      GET https://backend.sigfox.com/api/coverages/redundancy?lat={lat}&lng={lng}&mode={mode}
                      Parameters:
                      lat: the latitude.
                      lng: the longitude.
                      mode: the coverage mode (UNDERGROUND, INDOOR, OUTDOOR). This parameter is optional, default is INDOOR.
                      OUTDOOR: max link budget
                      INDOOR: link budget with dB margin
                      UNDERGROUND: link budget with dB margin
                      Response
                      "redundancy":3
                      Fields:
                      redundancy: the base station redundancy : 0 = none, 1 = 1 base station, 2 = 2 base stations, 3 = 3 base stations or more
                      I 1 Reply Last reply Reply Quote 1
                      • I Offline
                        irvinvp @iotmaker
                        @iotmaker My redundancy is 3, and the problem is only for messager after the first.
                        Always transmits without problems the first message every reboot!
                        • I Offline
                          irvinvp @irvinvp
                          @irvinvp said in Sipy only send first message when restart:
                            daniel
                            First of all apologies for the long delay with this. We have solved this problem with the latest firmware (1.6.13.b1). The issue is a bit complex and it's not because of a firmware bug, it's more because of an undocumented characteristic of the Sigfox network in RCZ2 and RCZ4:
                            There are 9 macro-channels with 2 micro-channels on each of of those 2 zones. However (and this is the undocumented part), only the first macro-channel is actually usable (for the time being). The Sigfox library itself behaves in a way that only the packets sent on the first macro-channel are transmitted properly (and the Sigfox library is a blackbox to anyone outside of Sigfox). The solution to this is to either call sigfox.reset() after every 2 transmissions and then wait 20s before transmitting again in order to comply with FCC regulations, or, as we have implemented it, handle this delay internally and only apply the amount of delay (if any) needed in order to comply. This latter approach is the one that we have preferred and therefore there's nothing to do at user code level besides knowing that more than 2 consecutive transmissions will have a delay in between. This is now documented in: https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html
                            This characteristics of the Sigfox network are not tested during the Sigfox certification phase and also not very well documented, which is why it took us so long to fix it.
                            Cheers,
                            Daniel
