<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Max voltage input on USB port]]></title><description><![CDATA[<p dir="auto">Which is the maximum input voltage on the USB port?<br />
Thanks</p>
]]></description><link>https://forum.pycom.io/topic/830/max-voltage-input-on-usb-port</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 18:58:37 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/830.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Mar 2017 15:58:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Max voltage input on USB port on Tue, 07 Mar 2017 15:58:44 GMT]]></title><description><![CDATA[<p dir="auto">Which is the maximum input voltage on the USB port?<br />
Thanks</p>
]]></description><link>https://forum.pycom.io/post/5022</link><guid isPermaLink="true">https://forum.pycom.io/post/5022</guid><dc:creator><![CDATA[Officina]]></dc:creator><pubDate>Tue, 07 Mar 2017 15:58:44 GMT</pubDate></item><item><title><![CDATA[Reply to Max voltage input on USB port on Tue, 07 Mar 2017 17:00:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/584">@Officina</a><br />
Normally USB spec say about 5.25V but it is specific to device.<br />
Why do you asking?</p>
]]></description><link>https://forum.pycom.io/post/5023</link><guid isPermaLink="true">https://forum.pycom.io/post/5023</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 07 Mar 2017 17:00:10 GMT</pubDate></item><item><title><![CDATA[Reply to Max voltage input on USB port on Tue, 07 Mar 2017 17:08:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/584">@Officina</a>, <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a> is correct, the expected input voltage should be 5.25 V in accordance to the USB standard. You should avoid connecting anything over 5.25 V via the USB port.</p>
<p dir="auto">You may wish to power the device over the Vin pin and you can safely connect a voltage source between 3.4 V and 5.5 V.</p>
]]></description><link>https://forum.pycom.io/post/5024</link><guid isPermaLink="true">https://forum.pycom.io/post/5024</guid><dc:creator><![CDATA[bucknall]]></dc:creator><pubDate>Tue, 07 Mar 2017 17:08:31 GMT</pubDate></item><item><title><![CDATA[Reply to Max voltage input on USB port on Tue, 07 Mar 2017 22:04:19 GMT]]></title><description><![CDATA[<p dir="auto">I want to connect a solar panel to usb port and using internal lipo battery charger. I found some solar panel with output around 5.5Volt.</p>
]]></description><link>https://forum.pycom.io/post/5030</link><guid isPermaLink="true">https://forum.pycom.io/post/5030</guid><dc:creator><![CDATA[Officina]]></dc:creator><pubDate>Tue, 07 Mar 2017 22:04:19 GMT</pubDate></item><item><title><![CDATA[Reply to Max voltage input on USB port on Tue, 07 Mar 2017 22:40:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/584">@Officina</a> said in <a href="/post/5030">Max voltage input on USB port</a>:</p>
<blockquote>
<p dir="auto">around</p>
</blockquote>
<p dir="auto">Without stabilizer it is risky because sometimes it become much more, nominal 5V but in sunning day it can be 7V</p>
]]></description><link>https://forum.pycom.io/post/5031</link><guid isPermaLink="true">https://forum.pycom.io/post/5031</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Tue, 07 Mar 2017 22:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to Max voltage input on USB port on Fri, 02 Feb 2018 19:33:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi...i am  a new user here. As per my knowledge 5.6v is out of spec and should be considered unsafe.  Most likely it will work, since USB ports tend to be poorly regulated and these devices take that into account with lots of safety margin, but you risk your player doing so.  You might want to look into putting together a 5v regulator circuit to be safe.</p>
<p dir="auto"><a href="https://www.7pcb.ca/contact-us/" target="_blank" rel="noopener noreferrer nofollow">complete pcb</a></p>
]]></description><link>https://forum.pycom.io/post/13376</link><guid isPermaLink="true">https://forum.pycom.io/post/13376</guid><dc:creator><![CDATA[NealXu]]></dc:creator><pubDate>Fri, 02 Feb 2018 19:33:01 GMT</pubDate></item></channel></rss>
