    SSL Connection IPProto_SEC Error SiPy
    websocketsipy
    5 Posts 2 Posters 1.9k Views 2 Watching
      Lokefar
      Re: SSL connection IPProto_SEC error
      Been trying to get this lib to work: https://github.com/Enabling/wipy-urllib/tree/master
      But I get the same error as in the older forum entry:
      AttributeError: 'module' object has no attribute 'IPPROTO_SEC'
      And as fare as I can read on the Git the code below is only for the WiPy 1
      sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_SEC)
      Any idea how to re-write the library to take this into account? Am using an SiPy.
        livius @Lokefar
        @Lokefar
        you can wrap socket by ssl
        https://docs.pycom.io/pycom_esp32/library/ussl.html?highlight=ssl
        this is good start point for conversion
          Lokefar
          @livius Thanks. I was already having a look at that but my initial thought is that it is a bit beyond my comprehension ability to convert it.
            livius @Lokefar
            @Lokefar
            instead of:
                        sock.settimeout(5)
                        s = ssl.wrap_socket(sock)
            s.connect(socket.getaddrinfo(host, port)[0][4])
            do (not tested but should be something simmilar)
            sock = socket.socket()
            s.connect(socket.getaddrinfo(host, port)[0][-1])
              Lokefar @livius
              @livius Did a quick try. Got the following error:
                File "/flash/lib/urequests.py", line 141, in urlopen
                File "/flash/lib/urequests.py", line 38, in __init__
              OSError: -32512
              Will look more into it later, but as fare as I can Google it might have something to do with the antenna transmission.
