Frame counter "fCnt" variable or setter function in LoPy
I would like to know if we can manually set frame counter in LoPy when sending message?
Thank you. -
Why do you want to set frame counter manually, isn't it the job of LoRaWAN stack? I can imagine a use case to set the initial value different than 0 when you initialize tha stack but not during normal operation.
@bmarkus I want to use it in ABP, to make the flame match the server flame counter. But now I think it is not the good ideal. Thank you for answering. Have a good day!
@bmarkus Yes.
