    W01 and L01 (OEM modules) drawings and reference designs
    hardware
    19 Posts 7 Posters 7.0k Views 9 Watching
      daniel
      Hello everyone,
      We have released the drawings and reference designs for our OEM modules. They are now available as part of the documentation here: https://docs.pycom.io/chapter/datasheets/oem/
      Cheers,
      Daniel
      J 1 Reply Last reply Reply Quote 2
        jmarcelino @daniel
        @daniel
        This is excellent! Thank you. Seeing lots of ground pins is great :)
        The reference board looks like an Altium design. Can the pcb document (pcbdoc) and/or component libraries be shared too please?
          daniel
          @jmarcelino yes, I'll make the Gerbers and Altium files available later today :-)
          A 1 Reply Last reply Reply Quote 1
            alangman @daniel
            @daniel where can we find the altium files?
              danielm
              Are you planning to release any reference design of a carrier board for your OEM modules? Especially one with on-board LoRa antenna (ceramic and/or PCB-trace) would really be helpful.
                jmarcelino @danielm
                @danielm
                I don't know about Pycom but I'm planning a breakout board using the Proant SMD metal antenna: http://www.proant.se/en/catalogue/embedded-antennas/--onboard-smd-antenna/onboard-smd-868915-antenna-pid55.htm
                I don't particularly like the PCB trace, ceramic or ceramic+PCB trace antennas for sub-1Ghz.
                  danielm
                  @jmarcelino
                  It seems to be very interesting, well documented antenna with a good price. Are you going to follow the application note for your PCB design? When do you expect to have some test results?
                    jmarcelino @danielm
                    @danielm
                    I evaluated this antenna with their eval kit and it worked very well for LoRa using the Laird RM186 module. Then I used just the part itself for a Sigfox prototype which has been performing nicely.
                    Proant is super friendly to deal with too they answered all my questions, just found out the other day that they designed the new Raspberry Pi Zero W "PCB cavity" antenna as well!
                    Yes I followed the application note. If you use Altium you can find a schematic and footprint library in my open source Sigfox PCB Ruler design
                      jmarcelino
                      Are there any 3D model STEP files for the OEM modules like there is for the LoPy/SiPy/etc ? I can't find it on https://www.pycom.io/downloads/#3d-models
                      I need it fairly quickly (next week) to show some board concepts to some interested parties - as well as have a open source board next month - so if there is something already sitting on someone's hard drive please release it :-) otherwise I'll need to commission one.
                      Also if someone - unlike me - has good 3D skills to make such a part message me and so we can work something out.
                        patrick
                        @daniel Any chance to get the Altium files and component libraries for the reference design available anytime soon? Or am I looking at the wrong place?
                          jmarcelino
                          I have an Altium symbol, footprint and 3D model ready now - this is my own, not official from Pycom.0_1495277416619_Screen Shot 2017-05-20 at 11.47.59.png ,
                          I'll make it public next month if there's nothing official until then. Hopefully by then I should also have had access to a real module to check.
                            daniel
                            I just updated the docs with the final drawings of the OEM modules and the reference designs. The complete Altium design files are also available for download.
                            https://docs.pycom.io/pycom_esp32/pycom_esp32/datasheets.html#oem-baseboard-reference-design
                            Cheers,
                            Daniel
                              danielm
                              @daniel
                              Thanks a lot. However, the zip file seems to be corrupt, I tried to extract it on two different PCs. Could you please check it?
                                livius @danielm
                                @danielm
                                for meee too
                                Yust for confirmation that this not only you.
                                  danielm
                                  @livius
                                  Thank you for confirmation.
                                  @daniel
                                  Could you please export the design in ACCEL ASCII format so we can try to import it into Eagle as described here:
                                  https://forums.autodesk.com/t5/eagle-forum/importing-files-from-altium-designer-to-eagle/td-p/6827258
                                    daniel
                                    @danielm and @livius thanks for the report. The file was indeed corrupted (git trying to "fix" the line endings). I have resolved the problem. Please try to download it again. Thanks!
                                      patrick
                                      Thanks Daniel, the zip isn't corrupted anymore and is working like it should :)
                                        danielm
                                        @daniel
                                        The zip file is OK now.
                                          scott @danielm
                                          @danielm @daniel I've uploaded my own Eagle library for the W01 WiPy OEM chip here
                                          Check yourself that you are happy that the libraries match the specs and are fit for your purposes.
                                          If the W01 library proves useful to people and there's enough interest then I could create and share an Eagle library for the L01 too.
