    Sipy -> Sigfox -> AWS
    sipyamazonaws
    8 Posts 5 Posters 2.6k Views 5 Watching
    • M Offline
      maku
      Anyone had luck with getting messages to AWS via callback?
      My response on the callback in Sigfox backend is:
      [OK] - Base station 29D0 - 1 second
      200 - OK
      [POST] https://data.iot.us-east-1.amazonaws.com/topics/sigfox?qos=1
      However I haven't been able to see the messages in AWS.
      If you follow the link in the POST method you get a "Missing Autehtication" which is sort of odd. Why is the link not of the form [id].iot.[server].....?
      • M Offline
        maku
        BTW:
        I followed: https://aws.amazon.com/blogs/iot/connect-your-devices-to-aws-iot-using-the-sigfox-network/ as tutorial. Any of you know if it is flawed?
        • I Offline
          iotmaker
          i have setup and it works really good... i did do something about the security policies...
          are you logging the info into a dynamoDB? or what are you doing with the AWS callback?
          • I Offline
            iotmaker
            Please post some screenshots of you AWS setup and i will compare them with mine which is up and working without problem.
              juriw @maku
              @maku I'm part of a project where we have used the same tutorial, and it worked perfectly! As your backend message says you are doing to callback right so you need to find the error log in AWS console to see what the problem is.
              And if I were you I would check the setup of AWS IoT and DynamoDB configurations.
              • M Offline
                maku
                Thanks for the replies. I got it all working now. It makes, typically, a minor setup error in AWS.
                If anyone with the same problem will ever be reading this thread I STRINGLY reckommend you rely on the Test function in MQTT client in AWS. It is found under AWS IoT and is pretty straigth forward.
                I did however not get the custom callback working.
                • M Offline
                  matt3526
                  Hi all,
                  I know this topic is very old but I'm having a problem similar and was hoping someone could help. I followed the same tutorial and I can see from the AWS IOT monitor that I have connections but there is nothing in my DynamoDB database. Can anyone help? Are there any tests that I should do?
                  • M Offline
                    Matthew Shuttleworth @matt3526
                    @matt3526 DID anyone figure this out?
