    How to use a Timer to blink a LED
    wipy 2.0led on off
    3 Posts 2 Posters 2.1k Views 2 Watching
      ColombianAus
      Hi there,
      I've followed following example form "5. Hardware Timers" with no success
      from machine import Timer
      from machine import Pin
      led = Pin('GP16', mode=Pin.OUT) # enable GP16 as output to drive the LED
      tim = Timer(3) # create a timer object using timer 3
      tim.init(mode=Timer.PERIODIC) # initialize it in periodic mode
      tim_ch = tim.channel(Timer.A, freq=5) # configure channel A at a frequency of 5Hz
      tim_ch.irq(handler=lambda t:led.toggle(), trigger=Timer.TIMEOUT)
      If I type every line into the REPL, I got following error...
      led = Pin('G16', mode=Pin.OUT)
      tim = Timer(3)
      TypeError: cannot create 'Timer' instances
      Now, if I follow the example under "Quick reference for the WiPy" (which is different to previous one!!!)...
      tim = Timer(0, mode=Timer.PERIODIC)
      AttributeError: type object 'Timer' has no attribute 'PERIODIC'
      I would appreciate any help in regards to:
      1. Has anyone found a Timer Tutorial here?
      2. What is wrong with the snip codes that I 've pasted?
      Cheers
      ColombianAus
        jmarcelino
        You're following the documentation for WiPy 1 but you have the new WiPy 2 which does Timers differently.
        All the new documentation is at https://docs.pycom.io
        The section you want is at https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/timers.html
        Use the Alarm example
          ColombianAus @jmarcelino
          @jmarcelino
          thank you mate...spot on. ...Do you know what is the most recent copy "Micropython Documentation"? for WiPy 2.0?
          cheers
          ColombianAus
