    Wipy 2.0 Firmware OTA update
    4 Posts 4 Posters 1.8k Views 4 Watching
    • K Offline
      katiusha
      My Friends, very very excited to have my 2 new Wipy 2.0 boards. Arrived today.
      However coming with 0.9.0b firmware I am trying to figure out how to upgrade them to the latest. Cannot find the files in GITHUB and I cannot afford for now the expansion board.
      Also I am trying to get the board to act as a station following the procedure in the doc's but with no luck. The boot.py file keeps the changes after power cycle and the AP default wifi ssid does not appear but it doesn't register in my network. All setting reviewed and are correct. My wifi is WPA2 AES encryption so in theory all is ok.
      Can you help me?
      Thank you!
        livius @katiusha
        @katiusha said in Wipy 2.0 Firmware OTA update:
        To upgrade it you can not use Wifi - it is still not supported
        Use any UART TTL -> USB converter
        or computer with RS232 - connect it to RX TX pin and do upgrade
        Remember that board is 3,3V not 5V.
        updater tool is here
        https://www.pycom.io/resources/
          pwest
          Two questions:
          Is this a planned capability?
          If so, when are we likely to see it?
          -Phil
            jmarcelino @pwest
            @pwest
            I'm sure it is and partly works already. I have an open enhancement request for it:
            https://github.com/pycom/pycom-micropython-sigfox/issues/5
