    Enable OrderedDict support by default
    Scheduled Pinned Locked Moved Enhancements
    micropythonucollectionsordereddict
    5 Posts 4 Posters 1.6k Views 4 Watching
      DvdGiessen
      (Hoping this is the right place to suggest this.)
      Support for the OrderedDict type was implemented in MicroPython a few years back, as part of the ucollections module. It doesn't seem to be enabled by default on the Pycom firmware versions. (The other data structure provided by this module, namedtuple, is available on Pycom firmware.)
      Implementation is already there, see https://github.com/pycom/pycom-micropython/search?q=OrderedDict&type=commits. Enabling by default would involve flipping MICROPY_PY_COLLECTIONS_ORDEREDDICT to 1 and probably updating tests (official MicroPython repo has some tests which don't seem to appear in the Pycom tree, yet).
      robert-hhR D 2 Replies Last reply Reply Quote 0
        robert-hh @DvdGiessen
        @DvdGiessen If you set up the build environment for pycom-micropython, you can easily add that yourself by adding the following line to esp32/mpconfigport.h:
        #define MICROPY_PY_COLLECTIONS_ORDEREDDICT (1)
          TravisT
          Is there a reason why this was left out, besides just saving space?
            DvdGiessen @robert-hh
            @robert-hh I'm aware, that why I mentioned that flag. I was suggesting it be enabled by default in PyCom's firmware releases. :)
              d.alvrzx @DvdGiessen
              @DvdGiessen coming to this several years later. Seems still not enabled in 1.20.2.rc6 firmware because still getting an ImportError when running from ucollections import OrderedDict :(
