Always reading same battery voltage
Sorry, can only post every 600s.
I am using pymakr (I know it isn't a good idea). What other options do I have to check?
But even when writing the value to a text file, without the usb, it is giving me the same value.
Hi @mmarkvoort,
Are you trying to measure the voltage while you have the board powered over USB, i.e. using the REPL to check?
When using the code that was given in the forum post (which uses attenuator 1) + changing to what you said (so changing it to 3).
I get this:
Mean of ADC readings (0-1023) = 1509.5199584960937
Mean of ADC readings (0-1400 mV) = 2063.7967586517333
Variance of ADC readings = 27.4036669731140
10* * 6 * Variance/(Mean**2) of ADC readings = 12.0000004768372When I use the adc from docs.
I get:
1520 and the next read 1530.It does change something, but still doesn't look good to me.
Does the USB cable matter?
try use attenuator (i do not know why it is not documented)
apin=adc.channel(pin='P13', attn=3)
do you use it like in post you link?
