DeepSleep and SHT31-D alarm
hello everybody,
I read all the discusion about the deep sleep mode, I have temperature sensor SHT31-D https://www.adafruit.com/product/2857 and it has alarm pin, I want to make my Lopy in deepsleep and when the tempareture will be at 30° my lopy should wake up, until now without success first juste with deepsleep,
I'm using this code :
n = 1 while (n > 0): pycom.rgbled(0xff0000) # red time.sleep(0.4) line = CreateDataLine(n) logfiledata(line) ds.go_to_sleep(10) pycom.rgbled(0x7f7f00) # green time.sleep(0.4) n += 1
I update the last firmware, and the SHT31 pins use P10, P9 , GND, 3V3
I hope to have an help or orientationkind regards
Maamar
@maamar
sh31 lib
from machine import I2C
import timeR_HIGH = const(1)
R_MEDIUM = const(2)
R_LOW = const(3)class SHT31(object):
This class implements an interface to the SHT31 temprature and humidity
sensor from Sensirion.
"""# This static map helps keeping the heap and program logic cleaner _map_cs_r = { True: { R_HIGH : b'\x2c\x06', R_MEDIUM : b'\x2c\x0d', R_LOW: b'\x2c\x10' }, False: { R_HIGH : b'\x24\x00', R_MEDIUM : b'\x24\x0b', R_LOW: b'\x24\x16' } } def __init__(self, i2c, addr=0x44): """ Initialize a sensor object on the given I2C bus and accessed by the given address. """ if i2c == None or i2c.__class__ != I2C: raise ValueError('I2C object needed as argument!') self._i2c = i2c self._addr = addr def _send(self, buf): """ Sends the given buffer object over I2C to the sensor. """ self._i2c.writeto(self._addr, buf) def _recv(self, count): """ Read bytes from the sensor using I2C. The byte count can be specified as an argument. Returns a bytearray for the result. """ return self._i2c.readfrom(self._addr, count) def _raw_temp_humi(self, r=R_HIGH, cs=True): """ Read the raw temperature and humidity from the sensor and skips CRC checking. Returns a tuple for both values in that order. """ if r not in (R_HIGH, R_MEDIUM, R_LOW): raise ValueError('Wrong repeatabillity value given!') self._send(self._map_cs_r[cs][r]) time.sleep_ms(50) raw = self._recv(6) return (raw[0] << 8) + raw[1], (raw[3] << 8) + raw[4] def get_temp_humi(self, resolution=R_HIGH, clock_stretch=True, celsius=True): """ Read the temperature in degree celsius or fahrenheit and relative humidity. Resolution and clock stretching can be specified. Returns a tuple for both values in that order. """ t, h = self._raw_temp_humi(resolution, clock_stretch) if celsius: temp = -45 + (175 * (t / 65535)) else: temp = -49 + (315 * (t / 65535)) return temp, 100 * (h / 65535)
from machine import I2C from machine import RTC from machine import SD from deepsleep import DeepSleep import machine import os import sht31 import time import pycom import math # to add in the boot.py the two lines #sd = SD() #os.mount(sd, '/sd') FILE_NAME = '/sd/datalog2.txt' #CURRENT_DATE_TIME = (2017, 8, 5, 00, 00, 00, 0, 0) def logfiledata (line): f = open(FILE_NAME, 'a') f.write(line) f.close() def CreateDataLine(i): th = sensor.get_temp_humi() dataCSV = 'TH'+str(i) +"\t" # point number #dataCSV += str(rtc.now()) + "\t" dataCSV += str(rtc.now()[0]) + "/" #year dataCSV += str(rtc.now()[1]) + "/" #month dataCSV += str(rtc.now()[2]) + " " #day dataCSV += str(rtc.now()[3]) + ":" # hour dataCSV += str(rtc.now()[4]) + ":" #min dataCSV += str(rtc.now()[5]) + "\t " #sec dataCSV += str(round(th[0],1)) + "\t " #Temperature dataCSV += str(round(th[1],1)) +"\n" #humidity return dataCSV pycom.heartbeat(False) #i2c = I2C(0) #i2c.init(I2C.MASTER, baudrate=100000, pins=("P9", "P19")) ds = DeepSleep() i2c = I2C(0, I2C.MASTER, baudrate=100000) sensor = sht31.SHT31(i2c, addr=0x44) th = sensor.get_temp_humi() time.sleep(0.6) pycom.rgbled(0xff007f) # magenta print("rev code 3") print("\n the Temperature SHT31 %0.2f C" % round(th[0],2)) print("\n the Humidity SHT31 %0.2f h" % round(th[1],2)) time.sleep(1) print("\n the Temperature SHT31 %0.3f C" % th[0]) print("\n the Humidity SHT31 %0.2f h" % th[1]) #print 'Temp = {0:0.3f} deg C'.format(th[0]) #print 'Humidity = {0:0.2f} h'.format(th[1]) time.sleep(1) rtc = machine.RTC() #lopy 7eca rtc.init((2017, 8, 5, 00, 00, 00, 0, 0)) print(rtc.now()) n = 1 while (n > 0): pycom.rgbled(0xff0000) # red time.sleep(0.4) line = CreateDataLine(n) logfiledata(line) ds.go_to_sleep(10) pycom.rgbled(0x7f7f00) # green time.sleep(0.4) n += 1 time.sleep(5.2) print("fin de programme ! maamar") pycom.heartbeat(True)
@robert-hh said in DeepSleep and SHT31-D alarm:
@maamar said in DeepSleep and SHT31-D alarm:
P10, P9 , GND, 3V3
A few questions:
- can you communicate with the SHT31 via I2C and get some actual readings?
yes and I store the Data on SD card
- did you program the device to use the alert pin?
not yet, I am strugling with driver
- to which xxPy Pin is the alert Pin of the SHT31 connected?
The code snippet you show is not very complete and has inconsistent indentation.
I will post again the code
@maamar Somehow the code did not upload. I have sent you two reputation ticks, maybe that enables it.
[1_1501939070055_sht31.py](Uploading 100%) [0_1501939070054_main-rev3.py](Uploading 100%)
this my code and the driver SHT31-D
P10, P9 , GND, 3V3
A few questions:
