    Power consumption on Pytrack with SiPy
    gpspytrackaccelerometerpower saving
    17 Posts 9 Posters 5.6k Views 11 Watching
    • E Offline
      Emmanuel Goudot
      In what state are GPS and accelerometer when SiPy is put in deep sleep mode (or sleep mode) ?
      I would like to put GPS in standby mode (to be able to perform quick fix), and setup accelerometer to raise interrupt on vibration (using INT1 or INT2 from LIS).
      Is it possible, as libraries only do basic tasks (read GPS position, read Accelerometer value) ?
        Jiemde Pybytes Beta @Emmanuel Goudot
        @Emmanuel-Goudot
        I have exactly the same questions ?
          bucknall
          @Emmanuel-Goudot We'll be releasing the wake on interrupt feature for the accelerometer very soon, we're currently tweaking the way that the pytrack/pysense modules behave whilst in deep sleep mode.
          Regarding the GPS, I'm currently reworking it to add increased functionality. I'll investigate the standby mode and look to implement this too.
          Thanks for your patience!
          Alex
          Developer Evangelist - Pycom
          • E Offline
            Emmanuel Goudot
            For GPS, looking at L76GNSS.py, it seems it is possible through I2C (GPS_I2CADDR) to send command to GPS.
            p.17 of Quectel doc states that:
            "Sending $PMKT161,0*28 will enter into standby mode, sending any data via UART1 will make the module exit from standby mode"
            Standby mode: 500µA
            So I guess it is possible to do it (myself).
            For accelerometer, some LIS registers will need to be setup.
            But what about INT1 or INT2 connections to ESP32 on Pytrack to raise an interrupt & wake up µP (from sleep or deep sleep) ???
              bucknall @Emmanuel Goudot
              @Emmanuel-Goudot Yes, the interrupts are currently connected to the onboard PIC of the Pytrack, which makes it a bit more difficult to manage regarding simply connecting the accelerometer to the ESP32 interrupts. We're working on this and will let you know when it's ready!
              joeriJ 1 Reply Last reply Reply Quote 0
              • E Offline
                Emmanuel Goudot
                I have now tested on Pytrack.
                After sending "$PMTK161,028\r\n" to L76, it seems that I2C scan loose 16 ID (remains [8, 30]).
                Is it normal behaviour ?
                Then after asking for deep_sleep (py.setup_sleep(SLEEP_TIME) and py.go_to_sleep()), is L76 still powered (so it really stay in standby) ?
                Third question: are electric schematics of pytrack avail to understand a bit more what is happening ?
                And is SW of PIC16LF1459 also avail ?
                Thanks, Emmanuel.
                  tveito @Emmanuel Goudot
                  @Emmanuel-Goudot
                  Hello, have a look at this post (tested power in deep sleep)
                  https://forum.pycom.io/topic/1460/power-consumption-deep-sleep-pysense-pytrack
                  • joeriJ Offline
                    joeri
                    Is there an update on this topic? I was hoping to use the interrupts in a project next week.
                    • joeriJ Offline
                      joeri @bucknall
                      @bucknall Can you give any updates on the availability of the interrupts?
                        bucknall @joeri
                        @joeri The library for the Deep Sleep Shield 'wake from interrupt' is available now. Daniel is working to implementing it in the Pytrack and Pysense and will be coming shortly.
                        Alex
                        J joeriJ 2 Replies Last reply Reply Quote 2
                          jcaron @bucknall
                          @bucknall @daniel any update on this? When will be able to wake on interrupt with the Pysense, at least for external pins (EXT_IO4/5)?
                            this.wiederkehr
                            Also eagerly (and a bit angry) waiting for this on pytrack but not to wake from deepsleep but just to have the interrupt routed to the esp32 as is shown on the pinout here:
                            This feature is advertised on the pinout but seems not available right now...
                            https://docs.pycom.io/chapter/datasheets/downloads/pytrack-pinout.pdf
                            Also see this thread:
                            https://forum.pycom.io/topic/1682/pytrack-lis2hh12-interrupts-make-i2c-bus-freeze
                            • joeriJ Offline
                              joeri @bucknall
                              @bucknall @daniel I'm having quite some power consumption issues with a prototype due to the accelerometer interrupt not being available. Now I need to regularly wake the board on a timer to check for movement which is not efficient.
                              Is there any update on a timeline for this feature to be released?
                              • E Offline
                                ekwus @joeri
                                @bucknall @daniel Can we get an update on progress here? I'm waiting on interrupt operation from the accelerometer as per the information I was sold the PySense board on!!
                                At least release the various schematics and information we would need to do this ourselves?
                                PyCom is quickly becoming great promises instead of great products. A lot of the reasons to pick your products over others are the fringe features you don't actually have but suggest you do.
                                Very poor and I'm sure I'm not the only one currently delaying projects and effectively loosing money after backing you as a supplier.
                                  asaph
                                  @bucknall @daniel my prototype is begging for sleep. any progress on accelerometer interrupt?
                                    asaph
                                    cross-referencing for relevant update (yay!)
                                    https://forum.pycom.io/topic/1861/accelerometer-wake-up-features-added-to-pytrack-and-pysense
                                    • joeriJ Offline
                                      joeri @asaph
                                      @asaph I've tried it out and it works fantastically 🎉 Thanks @Daniel!
