    Power consumption on Pytrack with SiPy
    gpspytrackaccelerometerpower saving
    17 Posts 9 Posters 5.6k Views 11 Watching
      tveito @Emmanuel Goudot
      @Emmanuel-Goudot
      Hello, have a look at this post (tested power in deep sleep)
      https://forum.pycom.io/topic/1460/power-consumption-deep-sleep-pysense-pytrack
      • joeriJ Offline
        joeri
        Is there an update on this topic? I was hoping to use the interrupts in a project next week.
        • joeriJ Offline
          joeri @bucknall
          @bucknall Can you give any updates on the availability of the interrupts?
            bucknall @joeri
            @joeri The library for the Deep Sleep Shield 'wake from interrupt' is available now. Daniel is working to implementing it in the Pytrack and Pysense and will be coming shortly.
            Alex
            Developer Evangelist - Pycom
            J joeriJ 2 Replies Last reply Reply Quote 2
              jcaron @bucknall
              @bucknall @daniel any update on this? When will be able to wake on interrupt with the Pysense, at least for external pins (EXT_IO4/5)?
                this.wiederkehr
                Also eagerly (and a bit angry) waiting for this on pytrack but not to wake from deepsleep but just to have the interrupt routed to the esp32 as is shown on the pinout here:
                This feature is advertised on the pinout but seems not available right now...
                https://docs.pycom.io/chapter/datasheets/downloads/pytrack-pinout.pdf
                Also see this thread:
                https://forum.pycom.io/topic/1682/pytrack-lis2hh12-interrupts-make-i2c-bus-freeze
                • joeriJ Offline
                  joeri @bucknall
                  @bucknall @daniel I'm having quite some power consumption issues with a prototype due to the accelerometer interrupt not being available. Now I need to regularly wake the board on a timer to check for movement which is not efficient.
                  Is there any update on a timeline for this feature to be released?
                  • E Offline
                    ekwus @joeri
                    @bucknall @daniel Can we get an update on progress here? I'm waiting on interrupt operation from the accelerometer as per the information I was sold the PySense board on!!
                    At least release the various schematics and information we would need to do this ourselves?
                    PyCom is quickly becoming great promises instead of great products. A lot of the reasons to pick your products over others are the fringe features you don't actually have but suggest you do.
                    Very poor and I'm sure I'm not the only one currently delaying projects and effectively loosing money after backing you as a supplier.
                      asaph
                      @bucknall @daniel my prototype is begging for sleep. any progress on accelerometer interrupt?
                        asaph
                        cross-referencing for relevant update (yay!)
                        https://forum.pycom.io/topic/1861/accelerometer-wake-up-features-added-to-pytrack-and-pysense
                        joeriJ 1 Reply Last reply Reply Quote 0
                        • joeriJ Offline
                          joeri @asaph
                          @asaph I've tried it out and it works fantastically 🎉 Thanks @Daniel!
