    Designing a board for the OEM modules
    bugsw01oemboard layoutimpedance match
    20 Posts 6 Posters 5.1k Views 7 Watching
      Richard @this.wiederkehr
      @this.wiederkehr thanks, good point. Luckily i am not going to use the antenna switch.
        jmarcelino @Richard
        @Richard
        Is this going to be a commercial product? If so I recommend having it done professionally, otherwise any problem may become more much more expensive in certification.
        If it's more a hobby thing then you could try without a matching network (or add one but just bridged with 0 ohm resistors or /unpopulated) You'll probably suffer range/bandwidth issues, but you'll be in good company with thousands of other products :-)
        The third option is to try and learnt if for yourself using something like the miniVNA. Warning this is a challenging - but rewarding - path.
          Richard @jmarcelino
          @jmarcelino Thanks, the third option sounds reasonable, since it may become a commercial product, when it's ready :-)
          I also found this statement in the ESP32 datasheet https://www.espressif.com/sites/default/files/documentation/esp32_datasheet_en.pdf in section 3.4.2:
          The use of digital calibration further improves the linearity of the power amplifier, enabling state-of-the-art performance of
          delivering +20.5 dBm of average power for 802.11b transmission and +17 dBm for 802.11n transmission.
          Additional calibrations are integrated to cancel any imperfections of the radio, such as:
          • Carrier leakage
          • I/Q phase matching
          • Baseband nonlinearities
          • RF nonlinearities
          • Antenna matching
          These built-in calibration routines reduce the amount of time required for product test and render test equipment
          unnecessary.
          Does that mean, that the antenna will adjust itself a bit to the board?
          J I 2 Replies Last reply Reply Quote 0
            jmarcelino @Richard
            @Richard said in Designing a board for the OEM modules:
            May well be true, but I think I see an antenna matching network inside Espressif's own module so I guess - even if true - it can only do so much.
              Richard @jmarcelino
              @jmarcelino said in Designing a board for the OEM modules:
              You do need impedance matching because the ESP32's output impedance is 30 + j 10 Ω, not 50 Ω.
              The datasheet Datasheet states that it is 30 + j 10 Ohm, but in the Hardware Design Guidelines i found this in section 3.2.1.4 RF
              The characteristic RF impedance must be 50Ω
              This is confusing ^^ What does that mean in practice?
              Is it a contradiction that the output impedance is 30 + j10 Ohm, but a 50 Ohm antenna should be used?
                jmarcelino @Richard
                @Richard
                Yes ESP32 documentation can be confusing - to everyone! :-)
                My interpretation is: if you look at the version history of the datasheet you can see it has been updated with the new value (30+j10Ω) from the original 50Ω back in May so someone must have realised that it was incorrect.
                The impedance of the ESP8266 was also a weird 39+j6 Ω so non-standard RF impedances are nothing new to Espressif.
                It's possible that that the phrase you quoted from the hardware design guide hasn't been changed to reflect this. The hardware design guide strongly suggests that you use a pi matching network anyway.
                  Richard @jmarcelino
                  @jmarcelino okay, thank you very much for your detailed answers, I appreciate this!
                  • I Offline
                    iotmaker @Richard
                    @Richard @jmarcelino
                    that miniVNA looks really good... I should have paid more attention to that class. I remember messing with the smith chart..
                      Richard
                      BTW, is the WiPy OEM module bluetooth certified? :-)
                      The Bluetooth listing may be affordable, but whole certification is far more expensive...
                        danielm
                        @jmarcelino
                        Is there any recommended design of pi matching network for external WiFi antenna connected through u.Fl connector?
                          jmarcelino @danielm
                          @danielm
                          Not that I know of. Personally - but I'm no RF expert - I'd just stick the known values into an online calculator such as https://www.eeweb.com/toolbox/pi-match
