    Atom Pymakr Serialport.node
    Scheduled Pinned Locked Moved Pymakr
    pymakratom
    35 Posts 12 Posters 14.9k Views 12 Watching
      jojo @RobTuDelft
      @RobTuDelft said in Atom Pymakr Serialport.node:
      and then edit package.json to use install-win for the install procedure
      I am not quite sure how to do that, can you tell me what I should modify in that file?
        balibo
          ssmith
          It seems everyone is not addressing the message that things were compiled with the wrong version.
          > At The module '\\?\C:\Users\Steve\.atom\packages\Pymakr\build\Release\serialport.node'
          > was compiled against a different Node.js version using
          > NODE_MODULE_VERSION 49. This version of Node.js requires
          > NODE_MODULE_VERSION 53. Please try re-compiling or re-installing
          > the module (for instance, using `npm rebuild` or`npm install`).
          RobTuDelftR 1 Reply Last reply Reply Quote 0
            politick @urblau
            @urblau Yes "Downgrading from Atom v1.19 to Atom v1.18" did fix my problem.
            but @ssmith is also right that the core issue is not resolved and Pymakr should be updated to be compatible with 1.19, but that is beyond what I need at the moment. I just need a IDE/platform that works.
            Thx! Martin Politick August 2017.
            • RobTuDelftR Offline
              RobTuDelft @ssmith
              @ssmith In install-win.js there is this command electron-rebuild -f -w serialport -v 1.3.13 which should recompile the serialport library. However it did not work for me at least. If you find something that works you can post it here https://github.com/pycom/pymakr-atom/issues/1
              Hackster | About me
                jojo @balibo
                @balibo
                Interesting article for those wanting to code using JavaScript, but I fail to see how this can help solving this problem.
                  jojo @politick
                  @politick
                  I guess I will do the same and wait until a new version of the plugin is released before upgrading to Atom 1.19.
                  Thanks everyone for your help and suggestions.
                    alexblack
                    A library is an organized collection of useful functionality. A typical library could include functions to handle strings, dates, HTML DOM elements, events, cookies, animations, network requests, and more. This article explains the basics and rudimentary differences between the most popular JavaScript libraries. Whether they become “best” for you is another question. But still all of them worth trying!
                    1 Reply Last reply Reply Quote -1
                    • K Offline
                      kuantsai
                      Same problem with serialport after the automatic upgrading (Windows 10, x64). Ended up downgrading Atom to 1.17 (I know my setup was working back in June), the problem seemed to have gone away (Atom 1.18 had the same incompatible serialport issue). Hope this helps,
                        Ralph
                        For who wants to try it, there is a fix for this issue on the develop branch now. See my last comment in https://github.com/pycom/pymakr-atom/issues/1#issuecomment-324798001. People seem to respond that it's working, so It'll likely be released soon.
                          Ralph
                          V1.1.0 has been released with a fix for this issue.
                          Note that the issue could re-appear if you are on 1.18.0. If it does, please update to the latest version (1.19.0 or higher).
                            simonjcarr
                            I have just received my LoPy boards today and am worried that I may have made a mistake.
                            I have tried to follow the instructions for connecting via atom, but the menus that you are asked to click on don't exist in the latest version of Atom.
                            Also when I click "Get Serial Ports" I get the following error
                            [Enter steps to reproduce:]
                            1. ...
                            2. ...
                            Atom: 1.19.5 x64
                            Electron: 1.6.9
                            OS: Microsoft Windows 10 Pro
                            Thrown From: Pymakr package 1.1.0
                            Stack Trace
                            Uncaught TypeError: No Binding set on SerialPort.Binding
                            At C:\Users\simon\.atom\packages\Pymakr\precompiles\serialport-win\lib\serialport.js:616
                            TypeError: No Binding set on `SerialPort.Binding`
                                at Function.SerialPort.list (/packages/Pymakr/precompiles/serialport-win/lib/serialport.js:616:11)
                                at Function.list (/packages/pymakr/lib/connections/pyserial.js:138:16)
                                at Pymakr.getSerial (/packages/pymakr/lib/pymakr.js:155:14)
                                at /packages/pymakr/lib/pymakr.js:75:13)
                                at emitNone (events.js:86:13)
                                at PanelView.emit (events.js:185:7)
                                at HTMLDivElement.PanelView.option_get_serial.onclick (/packages/pymakr/lib/main/panel-view.js:143:13)
                            Commands
                            Non-Core Packages
                            Pymakr 1.1.0
                            Can someone help me get started or point me to where there is some working documentation.
                              Ralph @simonjcarr
                              @simonjcarr This looks like a new issue indeed, I'll do some extensive testing on my windows 64 machine. Besides the missing menus (could you send me a screenshot of this) and this error when pressing Get Serial Ports, I'm guessing you are not able to connect to the board over serial? Are you able to use telnet and use the REPL? If needed you can change the IP setting via the alternative route of going to the atom preferences, plugins, then clicking the settings button of the Pymakr plugin.
                                simonjcarr @Ralph
                                @Ralph Sorry, I found the Global Config, Atom is new to me and I was looking under settings in the File Menu. This is should probably be updated in the docs, as not everybody has used Atom before.
                                Having found the global config, I have tried to connect to my COM Port, COM4 but it just hangs trying to connect. I also tried to connect to other COM ports the it immediately gives an error saying it can't connect, so it seems that COM4 is the correct port and Atom does try to connect but just hangs. I have tried two different devices and get the same problem, both devices have had the firmware updated today.
                                I have also tried to connect using putty and get the same problem, no error message, it hangs like it is trying to connect but never comes back with a failed message.
                                • ledbelly2142L Offline
                                  ledbelly2142
                                  I just tested it on Windows 10, upgraded from Atom 1.18 to 1.19, then updated the Pymakr plugin. Works for me.
                                    simonjcarr @ledbelly2142
                                    @ledbelly2142 Do I need Python installed. If so which version?
                                    Is there some documentation with screen shots for users who are new to Atom and LoPy?
                                      Ralph
                                      @simonjcarr With atom 1.19.5 on a 64b machine, I got to reproduce your problem. Connection over telnet works, but not over serial, and I get the same error when clicking Get Serial Ports. My development code is working on that same machine, so it should be something simple that got lost in the release.
                                      For now, try to use an alternative, I'll get back to you about this on monday. (Alternatives: using telnet only, downgrading to atom 1.18 + pymakr 1.0.3, using vscode, or use FTP + putty)
                                        ledbelly2142 @simonjcarr
                                        @simonjcarr said in Atom Pymakr Serialport.node:
                                        The instructions for installing the Atom plugin are HERE
                                        Installing Atom on Windows, download the Windows installer from atom.io from HERE
                                        Atom uses node.js and should install everything you need to run the Atom code editor.
                                        But... if you have issues with Node missing, you can download node.js as a windows installer HERE
                                        If you are installing Node, you have 2 options, version 6.11 or version 8.4. Both should work. I use version 8.
                                        So many development tools are using Node now that it's a requirement for tons of stuff, other than Atom.
                                        S 2 Replies Last reply Reply Quote 0
                                          @ledbelly2142 Thank you. Do I need to install Python or Micro Python as well?
                                            @simonjcarr So I uninstalled PyMakr. I installed node 8.4 and tried to reinstall PyMakr. Now I get a new error. Looks like I am not the only one. The same error was reported on the Git Hub page 22 hours ago.
                                            Atom: 1.19.5 x64
                                            Electron: 1.6.9
                                            Stack Trace
                                            Failed to activate the Pymakr package
                                            At "Bindings" is invalid pass it as `options.binding` or set it on `SerialPort.Binding`
                                            TypeError: "Bindings" is invalid pass it as `options.binding` or set it on `SerialPort.Binding`
                                                at /packages/Pymakr/precompiles/serialport-win/lib/serialport.js:119:11)
                                                at /packages/pymakr/lib/connections/pyserial.js:35:19)
                                                at /packages/pymakr/lib/board/pyboard.js:199:28
                                                at Function.isSerialPort (/packages/pymakr/lib/connections/pyserial.js:125:7)
                                                at Pyboard.connect (/packages/pymakr/lib/board/pyboard.js:196:14)
                                                at Pymakr.continueConnect (/packages/pymakr/lib/pymakr.js:246:21)
                                                at Pymakr.connect (/packages/pymakr/lib/pymakr.js:205:12)
                                                at /packages/pymakr/lib/pymakr.js:113:12)
                                                at Object.activate (/packages/pymakr/lib/main.js:17:19)
                                                at Package.module.exports.Package.activateNow (~/AppData/Local/atom/app-1.19.5/resources/app/src/package.js:253:25)
                                                at ~/AppData/Local/atom/app-1.19.5/resources/app/src/package.js:225:38
                                                at Package.module.exports.Package.measure (~/AppData/Local/atom/app-1.19.5/resources/app/src/package.js:99:21)
                                                at ~/AppData/Local/atom/app-1.19.5/resources/app/src/package.js:218:32
                                                at Package.module.exports.Package.activate (~/AppData/Local/atom/app-1.19.5/resources/app/src/package.js:215:40)
                                                at PackageManager.module.exports.PackageManager.activatePackage (~/AppData/Local/atom/app-1.19.5/resources/app/src/package-manager.js:645:40)
                                                at ~/AppData/Local/atom/app-1.19.5/resources/app/node_modules/settings-view/lib/package-manager.js:535:35
                                                at exit (~/AppData/Local/atom/app-1.19.5/resources/app/node_modules/settings-view/lib/package-manager.js:128:22)
                                                at triggerExitCallback (~/AppData/Local/atom/app-1.19.5/resources/app/src/buffered-process.js:338:17)
                                                at ChildProcess.<anonymous> (~/AppData/Local/atom/app-1.19.5/resources/app/src/buffered-process.js:368:17)
                                                at emitTwo (events.js:106:13)
                                                at ChildProcess.emit (events.js:191:7)
                                                at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                            Commands
                                                 -0:47.4.0 pane:split-up-and-copy-active-item (a.author)
                                            Non-Core Packages
                                            Pymakr 1.1.0
                                            https://github.com/pycom/pymakr-atom/issues/35
                                            ledbelly2142L R 2 Replies Last reply Reply Quote 0
                                            • 2 / 2
