    LoRa receiving data intermittently
    lopyrfm95adafruitfeatherarduino
    18 Posts 5 Posters 4.8k Views 6 Watching
      maelstrom @bmarkus
      @bmarkus Thanks, I just ordered a tuner to do some investigation. However I have had no issues transmitting between two RFM95 modules attached to Arduinos using the RadioHead library. Should I expect much variance in terms of tuning frequency across different LoRa radios? I did try some different frequencies around 915 but didn't know how granular I should get so
      I was pretty much poking around in the dark.
        maelstrom
        Ok so I did some poking around with different frequencies and only got one hit on 908000000 and it wasn't my GPS transmission from the M0. Also wanted to double check that the M0 was consistently transmitting so I fired up my other Arduino with the RFM95 and it picks up the transmissions perfectly every second. I am at a loss, this worked with very little troubleshooting using the RFM95 + Arduino.
        Here's what I was using to cycle through all the ISM 915 MHz frequencies at 100000 increments.
        from network import LoRa
        lora = LoRa(mode=LoRa.LORA)
        frequency = 902000000
            if frequency <= 928000000:
                lora.init(frequency=frequency)
                s.setblocking(False)
                time.sleep(1.2)
                print("Frequency: "+ str(lora.frequency()))
                data = s.recv(128)
                print(lora.stats())
                print(data)
                frequency = frequency + 100000
        • ledbelly2142L Offline
          ledbelly2142
          @maelstrom
          I am using firmware 1.8.0.b1
          I am using LoRa Nano-Gateway (Raw LoRa)
            maelstrom
            Looks there is a discrepancy between docs and implementation for coding_rate.
            modlora.c shows:
            typedef enum {
                E_LORA_CODING_4_5 = 1,
                E_LORA_CODING_4_6 = 2,
                E_LORA_CODING_4_7 = 3,
                E_LORA_CODING_4_8 = 4
            } lora_coding_rate_t;
            While docs indicate:
            lora.coding_rate([coding_rate]) Get or set the coding rate in raw LoRa mode (LoRa.LORA). The allowed values are: LoRa.CODING_4_5 (0), LoRa.CODING_4_6 (1), LoRa.CODING_4_7 (2) and LoRa.CODING_4_8 (3).
            I think this is just a documentation issue as setting the coding rate to 0 on the sx1272 would put it in FSK mode.
              ledbelly2142
              This is what I am using
              lora = LoRa(mode=LoRa.LORA, bandwidth=LoRa.BW_125KHZ, coding_rate=LoRa.CODING_4_8, sf=12, tx_iq=True)
              lora_sock.setblocking(False)
              with the 'nano-gateway' inside the office, we had a good signal up to about 1/4 mile with large buildings in the way. Still have intermittent issues and occasional corrupted messages.
                maelstrom @ledbelly2142
                @ledbelly2142 Thanks for the info. Right now I would say I am getting ~99% packet loss when receiving on the LoPy from an Arduino driven RFM95. To double check that I wasn't getting interference I had another Arduino/RFM95 receiving next to the LoPy and I received 100% of the packets. I also tried the reverse (LoPy transmitting, Arduino receiving) and did not receive anything. However if I had my GPS transmitter sending at the same time the LoPy would interfere with it so something is happening around the 915 frequency. I get my DVB-T tuner today so I will keep poking around.
                I have a feeling there is some default setting that is different between the Arduino and LoPy, I just cant figure out what it is and having 1% of the transmissions come across randomly is adding to the confusion.
                  JimT @maelstrom
                  @maelstrom
                  Is it possible to use FSK on the LoPy?
                    maelstrom @JimT
                    @JimT I am not sure.
                      maelstrom
                      Does anyone have a couple of LoPys running firmware 1.8.0.b1 and can test out the raw LoRa mode to confirm that this isn't a firmware issue?
                      I got my DVB-T tuner and nothing seems out of the ordinary and 915mhz in my basement is clean of interference. Even did some additional fine tuning of the frequency that the LoPy is listening on and still got intermittent results.
                      I am starting to wonder if there is a bad trace or ground that is contributing to this. I did have some issues when soldering the ground pin when I put in the headers, the board has a lot of grounding copper left on the PCB which acted as a heat sink so the solder didn't flow as well... maybe I will go resolver it to be sure.
                      • H Offline
                        husigeza @maelstrom
                        @maelstrom
                        LoRaRAW works for me between 2 LoPys both on EUR and US frequencies on the latest firmware, all the other parameters are default values.
