    Changing Frequency region after upgrade
    lopyfirmwarepymakrupdate toolupdate
    22 Posts 12 Posters 9.4k Views 12 Watching
    • bmarkusB Offline
      bmarkus @abilio
      @abilio said in Changing Frequency region after upgrade:
      @bmarkus: we have no means to keep track of the personal details of the customer associated with a specific device. Keep in mind that many of our sales go through resellers. We don't even keep the country, just the frequency (in the case of LoRa) or the region (in the case of Sigfox).
      There are no any reason to keep frequency. If you want to track device through sales channels, record HWEUI.
        abilio @bmarkus
        @bmarkus, can you please suggest in which practical way keeping a bool (0=868, 1=915) is considered a privacy issue?
        • E Offline
          Erica Galindo
          How this conversation looks to me right now.
          @bmarkus
          In terms of being spied i think my cellphone carrier even knows what i had for lunch yesterday, since they have my IMEI, SIM ID and credit card numbers.
          • bmarkusB Offline
            bmarkus @abilio
            You are putting a wrong question. It is a generic rule do not keep data you do not need. Keeping it and binding to update is not needed from the technical point (speaking about LoRa), makes customers life complicated in using a board he already payed, requires resources from your side, etc.
              abilio @bmarkus
              @bmarkus, we save it to make your life easier when after every release you have to update your boards. It saves you at least 3 clicks per device. For example, when you have 25 boards to update, it saves you 75 clicks in a very repetitive process that is prone to errors (there are countries of 915 MHz close to countries of 868 MHz). After 6 firmware releases, it would have saved you 450 clicks.
              Yes, you won't damage your board by mistakenly selecting a 915 MHz country when you really wanted an 868MHz one, but it can take you a lot of time figuring out why it stopped working all of the sudden ;)
              As I said before, we agree that the current updater lacks the option to change the band in case you made a mistake. But we are more focused on fixing firmware bugs than adding this feature, than in around 3 weeks, has only been needed once.
                rskoniec
                Right now I don't have my LoPys with me to check, but here is my idea:
                Default Pycom Firmware Update Tool Windows location is C:\Program Files (x86)\Pycom\Pycom Firmware Update
                1. Go into the Upgrader subfolder.
                2. Open lopyupdate.py file (in Notepad++, PSPad editor, etc.).
                3. Try to change self.__setFrequencySelectorVisible function calls from False to True (in the newest version of the upgrade tool lines 458 and 795 are candidates for change).
                4. Save the changes.
                5. Run the update tool.
                  livius @abilio
                  @abilio
                  If i can propose 3 things for updater:
                  1. add button change
                    or only select default frequency which was stored in pycom database for the device on drop combo box.
                  2. add possibility to run updater offline.
                    Updater check at start if there is new version
                    and if there is no internet connection look into folder if already files are there. If yes update board.
                  3. change default High speed unchecked.
                    GerryS @abilio
                    @abilio My LoPy is also set to work in the 915MHz band, but I need to have it work in 868MHz band. Please remove it from your database, my MAC is 240AC400CC82. Thanks!
                      johnmcdnz @abilio
                      @abilio I have the same issue.
                      For some reason my LoPy on upgrade changed to 868 when it should be 915.
                      I have tried doing downgrade to revert to the correct frequency, but with only an annoying partial success.
                      Following instructions here, I was able to downgrade and have 915, but if I then upgrade to the latest version the Upgrade tool again reverts to 868.
                      https://forum.pycom.io/topic/517/downgrading-firmware-advanced-users/2
                      My MAC address for this unit '24:0a:c4:00:b8:ac'
                      Please confirm how I can correct this. thanks.
                        jmarcelino @johnmcdnz
                        @johnmcdnz I’m afraid Abílio is no longer at Pycom, can you send your request to change the region by email to support@pycom.io please, it will probably get a better response.
                          johnmcdnz @jmarcelino
                          @jmarcelino Will do, thanks.
                            dhruv
                            Same problem here, I accidently chose different country when upgrading first time. Lora was supposed to be working on 915MHz frequency instead it is working on 868MHZ.
                            after going through above whole page ......when I enter following code
                            the wireless mac address came out to be [removed by admin]
                            sorry and thanks in advance.
                            • X Offline
                              Xykon administrators @dhruv
                              @dhruv I have changed your device from 868MHz to 915MHz. Please re-run the firmware update tool to flash the new region.
                              Christian Ehlers
