Controlling a servo with lopy (library or manually)
@robert-hh no worries mate, but yes - i did pull OE low. Connected it directly to GND on the lopy. Maybe a stupid question, but what is "SW" ?
@soren Software
@soren I just looked into the 74HCT125 data sheet. The minimum level for high is 3.15 V, close to the output level of the lopy. In that case I would check with an oscilloscope or logic analyzer whether the output of the gate really switches.
@robert-hh I can see with my multimeter that it's switching, but maybe that isn't accurate enough?
@soren Switching while you toggle manually? or between duty cycle 0 and 1?
Edit: I see 74HCT125 has a high input level of 2V, like the 74LS125. It's the 74HC125 with the 3.15 V level. So theer should be no problem with the levels. -
@soren said in Controlling a servo with lopy (library or manually):
For me setup 1 not worked when i tested it in the past with MG996R.
It does not react properly on 3v3 range pwm.
Setup 2 should work but i do not use convertes in chip
i trust simple design as converter on simple transistor eg. 2N7000.and to test if it work - try first run commands from terminal
pwm_c.duty_cycle(0.127 )
look at result but do not putsleepcommand
and decrese value
pwm_c.duty_cycle(0.117 )
pwm_c.duty_cycle(0.107 )
pwm_c.duty_cycle(0.097 )
...any results?
P.S.pwm_c.duty_cycle(1)is not good at all ;-)
i have done same mistake previously - as you can see in my post from the past -
@livius sleep() does not turn off the PWM.
yes, but it is not needed from terminal - this was my intention -
@livius I took everything apart, put it together and double cross checked several times the connections and then tried the pwm_c.duty_cycle() command from console - and it WORKED! @robert-hh I think time.sleep actually does affect pwm. At least it works now for me from console where I'm not using sleep - in contrast to what I did in the code.
@soren Good that it works. But omitting the sleep() commands are hardly the reason. I checked with an oscilloscope that PWM output stays when sleep() is performed. It's more something else you did. I worked with these servos decades ago, and remember that the pulse width range they expect is pretty small, from 1 ms to 2ms, at a 20ms period, resulting at a PWM duty cycle range between 5% and 10%
